Old Nov 25th, 2004, 07:01 PM   #1 (permalink)
BRSGXE
BRSGXE's Avatar
Question Header swap vs. Emission woes
If anyone has an answer to this, would greatly appreciate it. Looking
into swaping out the stock header on my 97 (1.6) and of course this
would leave only 1 cat in place. My only concern... Would it still be
possible to pass emissions? Thanks all.
1997 Sentra GXE 4 DR - 1.6, Auto: 3" K & N Cone filter, Home fabricated CAI, timing 15*, Mobile 1 synthetics, Front & rear strut bars, Front & rear euro lights, clear corners, rear spoiler, HD driving lights, Sun Pro tach.
"When my time on earth comes to an end...I want to go peacefully like my grandfather....
Not like the other people screaming in the back seat of his car." :thumbup:
BRSGXE is offline   Reply With Quote
Old Nov 25th, 2004, 07:18 PM   #2 (permalink)
Nismo1997
Drop-Out
Nismo1997's Avatar
Send a message via AIM to Nismo1997
As long as you still have the one cat I dont see any problem.
Nismo1997 is offline   Reply With Quote
Old Nov 25th, 2004, 07:46 PM   #3 (permalink)
timothyc1234
timothyc1234's Avatar
Send a message via AIM to timothyc1234 Send a message via Yahoo to timothyc1234
it should pass emissions. the stock manafold has the catalysts in it? i didn't know that. as long as you have a cat converter, you will pass emissions though no problem. its like imagine having two filters on something that filters out big crap and only big crap. the stuff that the cat picks up is the big crap. having two of them won't make much diffrence. good luck on installing your header. tim
1997 Nissan Sentra GXE 1.6L - Hope your next owner takes care of you
2006 Ford Focus ZX3 - I need to get into a ford forum...
1981 Toyota Tercel 1.5L - Turdcell
www.cardomain.com/id/timothyc1234
timothyc1234 is offline   Reply With Quote
Old Nov 25th, 2004, 07:48 PM   #4 (permalink)
Nismo1997
Drop-Out
Nismo1997's Avatar
NYS emission is a bit*h
Old Nov 25th, 2004, 08:40 PM   #5 (permalink)
konfuzion3
I Heart Your Fake Wheels
konfuzion3's Avatar
if you have an aftermarket header it will not pass emissions. just put the oem manifold back on when you go to have it smogged.
:showpics: kOnFuZiOn3kOnFuZiOn3konfvzion4@msn.com
konfuzion3 is offline   Reply With Quote
Old Nov 25th, 2004, 09:36 PM   #6 (permalink)
BRSGXE
BRSGXE's Avatar
Next time your under the hood, take a closer look at the manifold. Just under
the aluminum cover is a BIG OLE fugly fat cat.
Old Nov 25th, 2004, 09:38 PM   #7 (permalink)
timothyc1234
hehe kansas doesn't have emission laws. as long as i don't piss a cop off with noise i can run whatever i want for exhaust.
Old Nov 25th, 2004, 09:46 PM   #8 (permalink)
BRSGXE
BRSGXE's Avatar
Thought about that also.
Old Nov 25th, 2004, 09:51 PM   #9 (permalink)
Zac
Not Anymore.
Zac's Avatar
What does NY use, it it OBD2?
nothing to say
Zac is offline   Reply With Quote
Old Nov 25th, 2004, 10:09 PM   #10 (permalink)
Nostrodomas
Im out of here!!!!!!!!!!
Im not sure if it will pass. When im up for smog again, Im going to try to smog it with the header on. My uncle owns an electrical/smog shop, he said we can try it once. IF it doesnt pass, ill just have to R&R the own manifold.
I know for sure you wont pass the visual, unless you get a dumb smog tech.
Nostrodomas is offline   Reply With Quote
Old Nov 25th, 2004, 10:21 PM   #11 (permalink)
BRSGXE
BRSGXE's Avatar
Visual part I can slip under. Know of a few shops that will overlook
certain things, like only having 1 cat instead of 2. Since Cali is strict
on emissions, keep me posted on how you make out. If you pass, I
will DEFINITELY pass here in NY.
Old Nov 26th, 2004, 12:42 AM   #12 (permalink)
konfuzion3
konfuzion3's Avatar
The only way you're gonna pass emissions with an aftermarket header is if is CARB approved. If it's CARB approved, it will have a CARB # on it. If you don't have this # and badge, it will never pass emissions or visual. The only way it will pass is if you do it illegally.
Old Nov 26th, 2004, 06:42 AM   #13 (permalink)
psuLemon
i pwn your mom
psuLemon's Avatar
Send a message via AIM to psuLemon
every year i fail emissions since i have had the header on, but my mechanic will let it warm up and do a little tampering with it.. but this year they just obdII tested it... and if i didn't throw two codes, i passed, so its really on the mechanic and if everything else is good on your car, you might pass
Originally Posted by hendrix
I can't wait until Hurrican Jamal sweeps up the east coast and steals the wheels and stero out of your car
psuLemon is offline   Reply With Quote
Old Nov 26th, 2004, 10:23 AM   #14 (permalink)
Zac
Not Anymore.
Zac's Avatar
i asked earlier if it was OBD2 (aparently no one knows if your state uses it and it is rather important) because if it is, and you have a cat and the O2s are wired properly, then you wont get a CEL and hence you will most likely pass. A lot of places dont even bother with visual inspection.
nothing to say
Old Nov 26th, 2004, 10:41 AM   #15 (permalink)
psuLemon
i pwn your mom
psuLemon's Avatar
yea, apparently no one said it
correct me if i'm wrong...header install sethwas GA16DE 1.6L Engine 17 May 2nd, 2005 11:15 PM
HotShot Header or Nismo Header Sentra GTR-1 QR25 2.5L Engine 29 Dec 1st, 2004 07:55 AM
ton of e16i to e15t swap questions Daily88Sentra B11/B12/KN13 82-90 chassis 4 May 24th, 2003 03:41 PM
Will I past Emission test w/PS Header SentraBoy B13 91-94 chassis 9 Mar 29th, 2003 08:06 PM
Help! Muffler shop won't install header! OzPunk GA16DE 1.6L Engine 7 Feb 23rd, 2003 01:07 AM
