'92 Sentra GA16DE starting.... - Nissan Forum
post #1 of 17 Old Nov 22nd, 2004, 10:10 PM Thread Starter
Send a message via AIM to Modemagic
I just finished up the motorswap in my Nissan, even drove it around the block several times to see how she ran... she needs a bit of exhaust work, but otherwise not bad. After letting it sit over the weekend, I went out to start it and she simply would not start. Plenty of battery juice cranking the starter away. The Tach needle moves and it acts like it wants to start, just doesn't quite fire off. I got it started once, but letting it crank and crank till the tach reached over 1000 RPMs or so, then it ran rough for a few seconds and worked itself out and ran fine once I had it started.
After I completed the motorswap it took a bit of doing to get it started the first time, but that might have been due to the motor not running for awhile. After I got it running it did have a bit of an idling issue, mainly it dropped so low it didn't wanna idle, so I adjusted the throttle cable a bit and all went well.
Any ideas, thoughts, or suggestions as to why she doesn't wanna start??
Thanks,
Dave
'92 Nissan Sentra GXE - 198k and counting
Modemagic is offline
post #2 of 17 Old Nov 23rd, 2004, 07:54 AM
assuming your chains are positioned perfectly and i'm sure you put new plugs in there after the swap. since it started before i'm sure you're getting fuel. is it possibly flooded? pull a plug and check it. if it's flooded pull out all the plugs, disconnect the ignition and fuel pump, and crank over several times (give starter a breather in between these). put everything back but before you try to start it again, recharge your battery, even if it 'reads normal'. besides that, hmmm...is your air filter clean?
GA16DE
fritzfry is offline
post #3 of 17 Old Nov 23rd, 2004, 02:17 PM Thread Starter
Before I dropped the new motor in, I replaced the plugs, wires, distributor cap and rotor, water pump, thermostat, clutch, was going to do the front and rear main seals, but they had VERY recently been along along with new freeze plugs already in the motor. The air filter is not new, but its not very dirty either.
I can get the car to start by cranking on the starter and pushing the pedal to the floor, it will eventually start, but usually bogs down almost like its short on gas, but it will stay running. After I get it started, it will run and runs fine, although it accelerates a bit weak, not quite as peppy as it should be.
Thanks,
Dave
post #4 of 17 Old Nov 23rd, 2004, 02:30 PM
Post Freak
Send a message via AIM to Slacky
fuel pressure regulator vacuum line, or fuel pump dieing?
Slacky is offline
post #5 of 17 Old Nov 23rd, 2004, 10:18 PM
yeah, maybe check fuel pressure between the fuel filter and the rail. maybe also timing (my car wouldn't start when my upper timing chain was replaced a link off on the exhaust cam) issue?
GA16DE
fritzfry is offline
post #6 of 17 Old Nov 23rd, 2004, 11:37 PM Thread Starter
Just a thought I had so i took a can of starting fluid and shot it into the intake and turned the key and it cranked and started right up almost. After it started though, it died down and stalled... acting like a fuel problem to me. How can I check fuel pressure? I don't see a relief of any sort at the fuel rail, but I could be missing it....
Thanks,
Dave
post #7 of 17 Old Nov 23rd, 2004, 11:50 PM
Post Freak
well now u know its a fuel delivery problem, check the power comin out of the pump and unplug the regulator and fool around with it and all other fuel related parts see if u can alter any engine behavior
Slacky is offline
post #8 of 17 Old Nov 24th, 2004, 12:07 AM Thread Starter
I can here the fuel pump running... not that it means a whole heck of alot besides the fuse is good and the relay is good. Can I take the hose off the fuel filter and turn the ignition on and see if fuel spits out fast or not? Yeah, its a lame way to check it, but it should work.. right??
Thanks,
Dave
post #9 of 17 Old Nov 24th, 2004, 01:56 AM
absolutely classic
Kindfiend's Avatar
Don't do that... if you hear a whirring from the fuel pump when you turn the key, then it's probably not the pump. Good luck.
Kindfiend
01 Sentra GXE
92 SE-R
Kindfiend is offline
post #10 of 17 Old Nov 24th, 2004, 08:10 AM
if you have to do that, have a friend that can direct the hose into a small container. don't actually start the car, just turn the key until the pump turns on and fuel comes out then stop. but as said above, if you hear it activating, the pump is probably okay.
GA16DE
fritzfry is offline
post #11 of 17 Old Nov 28th, 2004, 12:42 AM Thread Starter
Is there any other sensors of the sort that could/would affect the starting of the car? I'm just wondering in case its not fuel related. I still have all my old motor parts, so taking a sensor off there and slapping it on would be a quick and easy fix.
Thanks all!
Thanks,
Dave
post #12 of 17 Old Nov 28th, 2004, 10:36 AM
Post Freak
lshadoff's Avatar
It sounds like a faulty injector. The spark plugs will tell the tale. After you get it running and drive until ti warms up, pull all the plugs and examine them. If one (or more) is black, that cylinder is running rich. Replace the injector with one from your old engine.
Lew
lshadoff is offline
post #13 of 17 Old Nov 28th, 2004, 05:00 PM Thread Starter
So basically clean them all up, get it started and run it a bit, then pull them back out and check it for a black plug?!?!
I just finished changing the fuel filter. Although the gas was nasty, yellow in color, but still no luck in starting it. I checked the motor over from top to bottom, and found two plugs that weren't connected that I cannot verify as to whether they should or shouldn't be plugged in or not.
The first is in the same harness as the alternator. Its a yellow/black wire with a small connector on it. Possibly a voltage meter wire?!?!
The second is under the distributor. Its a single yellow/green wire in a black female connector with a rubber boot around it. I noticed there is a male connector coming out the side of the motor, not sure what its purpose is. Does that wire go there?!?!
Thanks,
Dave
post #14 of 17 Old Nov 28th, 2004, 05:16 PM Thread Starter
So I went out and popped out the plugs. Look at the motor from in front of the car and counting left to right, both cylinders 1 and 3 even after being wiped off are still very black. Need to swap out both injectors?!?
Thanks,
Dave
post #15 of 17 Old Nov 28th, 2004, 06:59 PM Thread Starter
After getting it started and letting it run awhile... I noticed that the exhaust is rich smelling. (gas) Is this also due to the injector perhaps??
Thanks,
Dave
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
help replacing the heater core 92 sentra denismitchell B13 91-94 chassis 3 Dec 29th, 2008 06:47 PM
92 Sentra SER parts stripper scooterbob SR-Series Engines (DE/VE) 7 Sep 29th, 2004 01:41 PM
Sr20De into a 92 Xe Sentra pimpinboi B13 91-94 chassis 2 Sep 13th, 2004 11:38 AM
95 Sentra starting problem. davmil GA16DE 1.6L Engine 6 Feb 12th, 2004 06:30 PM
Twin weber sidedraft manifold for GA16DE engine in 94' Sentra? halfshaft Naturally Aspirated 2 Dec 9th, 2003 02:25 PM
You may post new threads
You may post replies
BB code is On
