Old Nov 12th, 2004, 12:45 AM   #1 (permalink)
IES200SXSE
hissing noise from motor...PLZ HELP!!!!!
i have a squealing noise coming from my motor...a guy said it sounded like a bearing is bad in my alternater...this only happend after i advanced my timeing...my idle goes to 1600 rpms when i disengage the clutch then back down after like 3 seconds...but im not worried about this...the hissing noise is what im getting tired of. has anyone had a problem like this?
LIVE LIFE AT THE RED LINE!!!!
NEVER THAT!!!
IES200SXSE is offline   Reply With Quote
Old Nov 12th, 2004, 10:27 AM   #2 (permalink)
pete?
Banned
pete?'s Avatar
Send a message via AIM to pete?
just to get the obvious out of the way before people start to throw out real technical stuff..................do you have an after market intake?
pete? is offline   Reply With Quote
Old Nov 12th, 2004, 05:14 PM   #3 (permalink)
IES200SXSE
yes i do but i know what that sounds like....this is more like a vaccum leak or something from the left side of the motor..(when you are looking at the windsheild.) plz help. it only started doing it when i advanced my timing.
NEVER THAT!!!
Old Nov 12th, 2004, 05:16 PM   #4 (permalink)
Shawn
Surf
Shawn's Avatar
Maybe your advanced timing is causing it to suck more air than before?
Sentra & F4
Shawn is offline   Reply With Quote
Old Nov 12th, 2004, 05:27 PM   #5 (permalink)
IES200SXSE
ill turn it back and see if it still does it but thank yall for the help..
NEVER THAT!!!
Old Nov 12th, 2004, 06:19 PM   #6 (permalink)
Token Moron
My ass, your face
Token Moron's Avatar
Send a message via AIM to Token Moron Send a message via MSN to Token Moron
how far did you advance the timing?
91 se-r : sr20det= the beast
96 sentra : ga16de= pimpness
00 frontier : ka24de= tow truck
01 sentra : gq18de= stock mofo
Token Moron is offline   Reply With Quote
Old Nov 12th, 2004, 06:38 PM   #7 (permalink)
Insert Name Here
Insert Name Here's Avatar
Send a message via AIM to Insert Name Here
It could very well be ur timing chain cuz mine is making that noise and I took off the VC and the chain was kinda loose and I figure that is what is making the noise.
:cheers:
Nissan Enthusiasts club starting in EPTX
Insert Name Here is offline   Reply With Quote
Old Nov 12th, 2004, 09:25 PM   #8 (permalink)
IES200SXSE
thanx man i will totally check out the timing chain.....because when this mechanic did my timing he turned my distributer all the way clockwise and i run 93 octane and there is no detonation...so i figure its ok...but i still dont understand how he says its at 13 degrees and its all the way turned...and i have read on these forums that it needs to be turned 15 degrees....does this sounds like a new timing chain? if so....plz send me info on prices how to links....thanx alot
NEVER THAT!!!
Old Nov 12th, 2004, 11:19 PM   #9 (permalink)
Sazbot
it may not be this, but mine was doing it from the same side of the engine.... check to see if it has a little water leak, even a TINY little one of the pipes squirting onto hot metal will make a really wierd noise
Sazbot is offline   Reply With Quote
Old Nov 13th, 2004, 12:54 AM   #10 (permalink)
IES200SXSE
it actually sounds like a spinning noise...almost like a vaccum leak but i bought all new vaccum hoses and everything so its not a bad hose...i dont want to buy a new alternater for no reason...
NEVER THAT!!!
Need help with tire noise on NX jb-nx2k New Member Forum 5 Mar 5th, 2006 07:03 AM
HELP: Strange (dangerous??) noise!! 92PF4X4 Truck & SUV 13 Dec 26th, 2005 08:18 PM
2004 Nissan Altima Steering NOISE AltiNick L31 2002 - 2006 8 Aug 30th, 2005 12:51 PM
2000 Altima Hissing Noise & Pulling nickcasa L30 1998-2001 Altima 4 Jul 19th, 2004 02:29 AM
Hissing noise Jay B14 95-99 chassis 6 Oct 25th, 2002 07:17 AM
