Old Oct 19th, 2002, 01:46 AM   #1 (permalink)
UnderDog
Nissan Addict
Send a message via ICQ to UnderDog Send a message via AIM to UnderDog Send a message via Yahoo to UnderDog
power loss at high revs
I noticed this happening after I advanced the timing to 15 degrees BTDC. I have 39 grand miles on the car and I've been running 93 octane gas since the day I bought the car. If I run the engine at WOT, when the engine speed hits about 4500 rpm, the power drops enough to feel it in my butt dyno, and you can actually see the needle slow down slightly. It's almost as if my A/C compressor kicked on all of a sudden and gave it a little drag. That's the only thing I can compare it to.
Is it possible it's sensing knock and retarding the timing? I don't know why it would do that, since I run high octane gas and my car is fairly new. If it is retarding the timing (back to say, 5 degrees or whatever), does the timing get readvanced to where I had it (15 degrees) when the knocking goes away? I never knew the answer to that one.
This isn't a life threatening problem, I just wanna know what's up with that.
'06 MkV Volkswagen GTI / DSG / REVO Stage I / AEM CAI / Custom 2.5" Catback
'99 Nissan Sentra GXE LE 1.6L A/T
UnderDog is offline   Reply With Quote
Old Oct 19th, 2002, 07:26 AM   #2 (permalink)
Centurion
freakish poster
Centurion's Avatar
I thought only the SE-R's had knock sensors (??).
1993 Sentra XE auto (original owner)
2005 NISMO Frontier
Centurion is offline   Reply With Quote
Old Jan 19th, 2006, 06:59 PM   #3 (permalink)
aalan
Hi, did you solve the problem? I have the same problem right now.
aalan is offline   Reply With Quote
Old Jan 20th, 2006, 11:15 AM   #4 (permalink)
oliverr87
Nissan Fanatic
Send a message via AIM to oliverr87 Send a message via MSN to oliverr87 Send a message via Yahoo to oliverr87
Check your plugs, plug wires, and distributor cap.
oliverr87 is offline   Reply With Quote
Old Jan 20th, 2006, 01:37 PM   #5 (permalink)
psuLemon
i pwn your mom
psuLemon's Avatar
Send a message via AIM to psuLemon
check your timing again. it sounds like its retarding at high rpms do to knock like you said. If you have to, set your timing at 13 degrees and see if you notice a difference
Originally Posted by hendrix
I can't wait until Hurrican Jamal sweeps up the east coast and steals the wheels and stero out of your car
psuLemon is offline   Reply With Quote
