Old Oct 26th, 2004, 10:35 PM   #1 (permalink)
Skoodles
wont go any faster?
Skoodles's Avatar
Send a message via AIM to Skoodles Send a message via Yahoo to Skoodles
advanced timing could this be detination
yeah yeah yeah there are a million threads on this one and my question prolyl most like the others but hear this out i advanced teh timing on my 96 200sx and low rpm it runs fine idles kinda rough but nothin big but when im gunning it and the vtc kicks in it sounds kinda like its hitting a rev limiter just not as harsh and it keeps accelerating is this detination and i got a quarter tank left and just put some octane boost in it and it seems to run better so what was i getting detitnation?
Skoodles is offline   Reply With Quote
Old Oct 26th, 2004, 10:48 PM   #2 (permalink)
Fernan Abracosa
For your car u must follow these;
Timing - 8° BTDC
Idle Speed-625 RPM
92+ octane gasoline is mandatory
Fernan Abracosa is offline   Reply With Quote
Old Oct 26th, 2004, 10:51 PM   #3 (permalink)
Nismo1997
Got Boost?
Nismo1997's Avatar
Send a message via AIM to Nismo1997 Send a message via Yahoo to Nismo1997
What did you advance the timing to? Did you run 93 octain a Tank before as said in thread?
Nismo1997 is offline   Reply With Quote
Old Oct 26th, 2004, 11:01 PM   #4 (permalink)
Fernan Abracosa
Hey Nismo1997,
How many miles does a gallon get you? Or how many kilometer per liter?
Old Oct 26th, 2004, 11:03 PM   #5 (permalink)
Nismo1997
Got Boost?
Nismo1997's Avatar
Originally Posted by Fernan Abracosa
Hey Nismo1997,
I really dont know. I used to get like 400miles to a full tank. Now im lucky if I hit 320.
Old Oct 29th, 2004, 01:27 AM   #6 (permalink)
Togie
I think you have to try platinum or iridium NGK spark plug. When it get so hot yours may be turning red in flames and can't burn the fuel efficiently.
Let us know what happen okay...
:cheers:
Sentra GXE 4dr - GA16DE B13
Togie is offline   Reply With Quote
Old Oct 29th, 2004, 08:33 AM   #7 (permalink)
wes
Wise Cracker
wes's Avatar
Send a message via AIM to wes
The plugs aren't going to help really, detonation is more heard than felt unless it is REALLY bad. The best way to describe the pinging sound of detonation is "like keys jangling underwater". What do you have it set at? Many people run 15 degrees on premium fuel without issues and make SURE you are adjusting the timing correctly.
www.NissanPerformanceMag.com
JWT
www.notnser.com
Old Oct 30th, 2004, 10:51 AM   #8 (permalink)
Skoodles
wont go any faster?
Skoodles's Avatar
mines set around 15 degrees and i just run octane boost to boost ym octane up to about premium and i did it the correct way but i had a problem while disconnectign the tps it kills the car so i revved it the few times and had to plug it back in then time it prolly wrong but it laggs on low rpm but pulls crazy on higher rpm
Old Oct 30th, 2004, 12:40 PM   #9 (permalink)
wes
Wise Cracker
wes's Avatar
yes it;s wrong and your timing is probably waaay advanced. If your car is dying when you disconnect the TPS you need to adjust/raise the base idle. The FSM outlines this for checking the timing. I would re-do it before you find yourself tearing apart that motor again.
JWT
www.notnser.com
Old Nov 1st, 2004, 10:26 AM   #10 (permalink)
BikerFry
Come here often?
BikerFry's Avatar
Timing - 8° BTDC
Idle Speed-625 RPM
One of your numbers is wrong, either the 8 or the 92.
8* BTDC is stock timing, so 87 octane would be fine but you'd have no power gain.
15* BTDC requires 91+ and will net close to 5hp in the midrange and around 2hp peak.
Is this forum still full of n00bs learning that you can't boost your daily driver on a part time retail income?
BikerFry is offline   Reply With Quote
Old Nov 1st, 2004, 08:24 PM   #11 (permalink)
Togie
Hey BikerFry,
I got a Sentra 1.6 GXE 4dr 1992 my ignition timing is 12*, gas is 93 octane idle speed is 900 with load 750 w/o load. Consume 1liter per 9.8 kilometer. Can I push the timing to 15*?
:cheers:
Old Nov 1st, 2004, 10:53 PM   #12 (permalink)
Skoodles
wont go any faster?
Skoodles's Avatar
no i got it figured out now when i pulled tps sensor and rev it enough it will start to idle at 1500 then yout ime it and yeah it was way advanced so now i got it to abotu 13* and its running like a bad out of hell now glad i got that figured out
Old Nov 2nd, 2004, 07:07 AM   #13 (permalink)
BikerFry
Come here often?
BikerFry's Avatar
Originally Posted by Togie
Hey BikerFry,
You shouldn't have any trouble running 15* with 93 octane gas. But if I did my math right you're getting 23 miles per gallon, which is pretty crappy even in city driving. Might want to do a tune up.
Old Nov 2nd, 2004, 02:16 PM   #14 (permalink)
xNISMOB14x
xNISMOB14x's Avatar
Send a message via AIM to xNISMOB14x
I have a 98 nissan 200sx se Auto how can i do this to mine and if i can will it help me out?
xNISMOB14x is offline   Reply With Quote
Old Nov 2nd, 2004, 02:25 PM   #15 (permalink)
wes
Wise Cracker
wes's Avatar
You can do a search on this topic as it has been covered MANy times and he procedures are listed. Yes it will help provided you run premium fuel (>91 octane)
JWT
www.notnser.com
Just advanced timing, weird ticking/pinging. nemui_panda GA16DE 1.6L Engine 4 Oct 18th, 2004 08:32 PM
Advancing my timing issues 200sxOuTKasT GA16DE 1.6L Engine 22 May 20th, 2004 12:40 AM
advanced timing on ga16det kwertis Forced Induction & Nitrous Oxide 3 Apr 8th, 2004 07:29 PM
ga16de advanced timing - how far to take it. darkelf Naturally Aspirated 6 Nov 14th, 2003 06:45 PM
Advanced my timing... questions and problems.. expert help plz LaRon B14 95-99 chassis 9 Jun 11th, 2003 02:41 PM
