Old May 22nd, 2002, 06:06 PM   #1 (permalink)
Toda Party
Posts: n/a
99 GXE Valve lash specs
anyone know the valve lash specs for this motor?
Old May 23rd, 2002, 01:52 PM   #2 (permalink)
Toda Party
Posts: n/a
Old May 23rd, 2002, 02:04 PM   #3 (permalink)
James
in^3,N20,RPM,PSI
James's Avatar
don't have it in front of me right now... can you wait till tonight? what do you need it for anyways?
Old May 24th, 2002, 10:20 AM   #4 (permalink)
Toda Party
Posts: n/a
well im driving around my dad's car, with 90,000+ on it...and i dont think he ever did a valve adjustment on it so...
Old May 24th, 2002, 11:05 AM   #5 (permalink)
James
in^3,N20,RPM,PSI
James's Avatar
sorry haven't had a time to check yet... got history final today.
if your car is 95+ model GA then you have hydraulic adjusters. outside of new camshafts I don't think you'll need to get them adjusted. they're capable of being adjusted mechanically by shims but Nissan dealers will laugh at you when you tell them you need them adjusted. they think you can't adjust them which is partially true, but you can.
Old May 24th, 2002, 12:14 PM   #6 (permalink)
Toda Party
Posts: n/a
that's interesting, i've never heard of that before.
thanks for the info, I'm still gonna pull the valve cover off and poke around, but I guess i wont be needing to adjust the valves then. thanks
Old May 24th, 2002, 12:25 PM   #7 (permalink)
James
in^3,N20,RPM,PSI
James's Avatar
make sure you have the right guages.
Old May 25th, 2002, 01:21 PM   #8 (permalink)
wes
Wise Cracker
wes's Avatar
Send a message via AIM to wes
Post Hydraulic?
I have a completely disassembeled cylinder head sitting here. It's a direct acting valve train. The FSM recommends checking the valve clearance as part of the 30 and 60K service intervals. I recommend you pick up the FSM, not only does it outline the given tolerances it also show you how to remove the shis=ms without removing the cam shafts. When you do check them, the FSM recommends that you check them when the engine is warm, this way you get accurate readings with expansion.
www.NissanPerformanceMag.com
JWT
www.notnser.com
Old May 25th, 2002, 02:06 PM   #9 (permalink)
Toda Party
Posts: n/a
FSM? I'm assuming that is a ____ Service Manual...
Not to start an arguement or anything, but when I checked valve clearances on my Integra, we and everyone I've talked to always do it cold, because doing it warm was supposed to give you inaccurate readings because of the expansion from the heat...so then when you adjusted it warm, you actually adjusted it to the wrong spec... shrug
Old May 25th, 2002, 11:43 PM   #10 (permalink)
samo
shut up.
samo's Avatar
Send a message via AIM to samo
Originally posted by Toda Party
____ Service Manual
Factory.
When the car runs, it's warm, so it would seem to me that adjusting the valves when the car is warmed up would give you the correct adjustments for the majority of the life of the car.
29A
1993 Subaru Loyale Wagon 4WD
Check out my Cardomain site / Hit me up on AIM: samo ownz yuo
samo is offline   Reply With Quote
Old May 26th, 2002, 10:15 AM   #11 (permalink)
lakalakalakalak
Posts: n/a
WHere could I buy a factory service manual? I bought my car used.
Old May 26th, 2002, 10:48 AM   #12 (permalink)
By Nature
Nissan Fanatic
Send a message via AIM to By Nature
Originally posted by samo
Factory.
yeah, but the specs in the FSM are probably taken from a cold engine with warm engine tolerances, because if they're measured warm then there should be a specific temparature at which to measure clearances
"Those who stand for nothing, will fall for anything"
2003 VW Jetta 1.8
1998 Nissan Sentra 1.6
By Nature is offline   Reply With Quote
Old May 27th, 2002, 12:27 PM   #13 (permalink)
Toda Party
Posts: n/a
that makes sense
Old May 28th, 2002, 09:47 AM   #14 (permalink)
James
in^3,N20,RPM,PSI
James's Avatar
Re: Hydraulic?
wes, i was trying to get my valves adjusted a while back and had a problem with the local dealership. they kept telling me that the lifters were hydraulic and no need to adjust them... well I talked to Greg at Mossy and he confirmed that they were hydraulic... I have found many places that have said the 95+ GA's were hydraulic. I think it uses the shims for major adjustments...
any ideas? I'd like to know myself (I know everywhere says it's mechanical... but the technicians at Nissan always say it's hydraulic. I just want to know myself what it is for sure.)
Old May 29th, 2002, 05:27 PM   #15 (permalink)
PatScottAKA99XE
ex-Super *********
PatScottAKA99XE's Avatar
Send a message via AIM to PatScottAKA99XE Send a message via Yahoo to PatScottAKA99XE
Since I work at a dealership, Ill chime in on this one.
Warm/hot vs. cold - Which ever the manufacturer tells you to. When they give you a cold spec, that spec accounts for the heat expansion.
Here are the specs for the GA16DE - Intake valve/.008 to .019 in, Exhaust valve/.012 to .023 in, These specs are with the engine hot
Patrick Scott
Yeah, thats a roll cage in there.
I shall call him...Mini-Me
PatScottAKA99XE is offline   Reply With Quote
EVAP canister vent control valve closed large168 SR-Series Engines (DE/VE) 29 Apr 21st, 2008 04:52 PM
Engine difference between GXE and GXE LE? Jimmymus GA16DE 1.6L Engine 12 Oct 2nd, 2004 03:35 PM
sr20de valve cover torque specs sr20speed SR-Series Engines (DE/VE) 2 May 20th, 2003 04:33 PM
emissions and missing PAIR valve (whatsa PAIR valve do anyway..?) NXtremese-r SR-Series Engines (DE/VE) 1 Mar 3rd, 2003 06:00 AM
Adjusting Valve Lash LittlebittaContact E/CA-Series & GA16i Engines 8 Oct 24th, 2002 08:25 PM
