strange oil leak - Nissan Forum
post #1 of 19 Old Oct 15th, 2002, 04:23 PM Thread Starter
strange oil leak
hi all
i have a 92 nissan sentra 1.6l auto and under the hood, i see oil all over the engine. it surely isnt leaking from the engine head, but it seems to come somewhere near the distributor area as the distributor is covered in oil, i mean i can see some oil holding at the bottom part of the distributor. its very strange how the oil comes till the distributor. anyway the leak isnt bad as the oil level doesnt go bad very often. but all i am worried is if it gonna be bad in the long run?
thanks
maheshwar kaladar
mk_sentra is offline
post #2 of 19 Old Oct 15th, 2002, 07:16 PM
wes
Wise Cracker
wes's Avatar
Send a message via AIM to wes
Post Problem.
You shoudl pull off the valve cover and buy a new valve cover seal. You'll also need to reapply RTV to the distributor area. I bet the RTV and or valve cover gasket is leaking.
wes is offline
post #3 of 19 Old Oct 15th, 2002, 10:43 PM
Nissan Fanatic
V i V i D 200sx's Avatar
Send a message via AIM to V i V i D 200sx
yeah, i would check the valve cover gasket
'95 200sx SE = konig divas on 185/60R-14 Kumho 716s, open-airbox, k&n filtercharger, 1.3 bar radiator cap, all red taillights, removed black doorframe vinyl, mesh grill, remote start alarm, no-chrome window frame, sylvania silverstars, optima red top, w/ 4AWG ground, full kenwood sound system.
V i V i D 200sx is offline
post #4 of 19 Old Oct 16th, 2002, 04:45 AM
ace
if you see oil concentrating around the area where distributor meets the valve cover, then it is possible that the leak comes from the distributor.
To check, remove the distributor cover and see if there is evidence of oil or burnt oil.
If yes, then remove the entire distributor and check the O ring.
It's quite likely that the O ring is worn out or hardened , which results in the leak.
A drippy distributor will result in hard starts and poor ignition firing and in the long run, high fuel consumption.
I had a similar problem. Replaced the distributor and by chance, saw that the O ring had worn out.
After that, no more leak.
Also check the engine cover (near the distributor) for RTV that may have been dislodged and caused a gap where the oil will flow out.
Another check is the engine cover seal (shaped like the outline of the engine cover.. as mentioned below). If it's hardened, then time to change it.
Hope it helps.
ace is offline
post #5 of 19 Old Oct 22nd, 2002, 07:56 PM
Nissan Addict
Send a message via Yahoo to superfro86
what could it be if it was leaking near the alternator? I dont think its the valve cover gasket but i'm not sure
They should have never gave y'all niggaz money!!
(note: this is from the dave chappelle show ie rick james vs. charly murphy sketch so dont ban me for racist comments and i'm black anyway)
superfro86 is offline
post #6 of 19 Old Nov 5th, 2002, 06:33 PM Thread Starter
near the alternator too
actually there's oil leaking near the alternator too. i see thick oil dirt nearly wet under the altenator.
post #7 of 19 Old Nov 5th, 2002, 07:12 PM
Your electrical friend
toolapcfan's Avatar
If you can't find the leak easily, degrease and wash the engine really good and get it nice and dry, then check on it every day to see where the leak develops from.
Rob '93 SE-R
PM or e-mail me for Progress swaybars $190 shipped, B13 Progress coilovers $1300 shipped and B13 Progress LCA brace $160 shipped.
toolapcfan is offline
post #8 of 19 Old Nov 5th, 2002, 08:35 PM
Nissan Addict
Send a message via AIM to BORNGEARHEAD
If you have oil near the alternator I would have to say it's the front crank seal. When it leaks, the oil gets slung around. I have seen some with the alternator just saturated with oil. It can cause the alternator to go bad. As for the distributor leak, I have seen distributors go bad from oil. Those are not cheap to replace.
93 NX2000 w/sr20ve
98 Frontier
BORNGEARHEAD is offline
post #9 of 19 Old Nov 5th, 2002, 10:30 PM Thread Starter
distributor removing
hi
i was wondering if i could remove the distributor myself .
i think the timing should be set properly after removing the distributor right?
post #10 of 19 Old Nov 5th, 2002, 11:03 PM
if you're getting oil all over your alternator and on the belts, and anywhere else in the area, i'd agree with the above. I just had my front crank seal replaced- it leaks, hits the belts and get thrown everywhere. I mean everywhere. But its usually a small common problem with the engine, any nissan dealer can probably fix it for around a 100 bucks (depends on labor and if they need to change the belts)... don't let it go too long, the oil will make the belts loose, and that just can't be good.
Phil Minchoff
phil_minchoff is offline
post #11 of 19 Old Dec 23rd, 2002, 05:07 PM Thread Starter
think it is the front crank seal
hi
i think it is the front crank seal. the leak used to be small before. say, i find some oil hanging onto the oil pan and the cv rod. then i made a very long trip to the smokies in NC for the weekend and today I am back home in FL and i see oil all over the lower engine area. the internal area of the wheels, the cv rod alternator belts and all other belts in that area.
how bad has it become given the fact that i drove 1600 miles for the weekend and the oil level going from high to 30%high in 3 days?
mk
post #12 of 19 Old Dec 23rd, 2002, 05:19 PM
Nissan Addict
mine has a bunch of sludgey looking oil right on that flat spot near the passenger side headlamp to the left of the water resovoir. i'm going to check put it on a lift and check it out next semister when we go back to school. how much does a front crank seal cost anyway? just the crank seal not labor i can get that for free.
post #13 of 19 Old Dec 23rd, 2002, 05:29 PM Thread Starter
are you replacing it yourself
hi superfro86
are you replacing the front crank seal yourself? how much time does it take and what are the steps?
post #14 of 19 Old Dec 23rd, 2002, 05:35 PM
Nissan Addict
i myself don't have a clue. i'm going to do it in autotech and let my teacher tell me how to do it then use his stuff since they got lifts and all that.
post #15 of 19 Old Dec 24th, 2002, 12:31 PM
P.O.S. Truckdriver
Katana200sx's Avatar
front main seals on our cars suck ass! it seems like everyone w/a ga16de powered car has their's go bad at some point. ya'll should see my engine. i never cleaned the block of anything else the oil got on bc i didnt think it was that bad. but when i changed my belts and took a good look around the engine, it was horrible. btw, gunk engine brite works great at cleaning your engine bay and block. works even better if you have an old toothbrush.
Need parts?
91 SE-R Partout
96 200SX SE Partout
Katana200sx is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
You may post new threads
You may post replies
BB code is On
