» Sponsors
» Sponsors
Go Back   Nissan Forums: Nissan Forum > Nissan Models > Sentra, Pulsar, NX, B14 200SX > GA16DE 1.6L Engine
Old Aug 30th, 2004, 12:23 PM   #1 (permalink)
THINK BLUE
Wufaded's Avatar
Send a message via MSN to Wufaded
How-To: Change Oil Pressure Switch
I recently change the oil pressure switch (OPS) on my GA16DE, and thought I would write a quick How-To on it. I changed the OPS while I was changing the oil, thus the Oil Filter was off during the procedure. There might be enough clearance to change the OPS with the oil filter on, but I'm not 100% sure. Might as well change the oil while you have the car jacked up. Anyway on to the write up...
To swap the OPS you will need:
- New OPS. I got mine from Kragen, and AutoZone carries them also. And of course, you can get them from a Nissan dealership.
- A 26mm or 1-1/16" Deep Socket. Both of them fit the OPS, just make sure you have a deep one. I had to get the Standard size because Kragen didnt carry the 26mm deep socket.
- Teflon tape
For an oil change step by step, check this out:
http://www.nissanperformancemag.com/august04/oil_change
Instructions:
1. Jack the car up on stands or on ramps
2. Drain oil in suitable pan
3. Remove oil filter
4. Locate OPS, near the oil filter
5. Disconnect electrical connector on OPS
6. Remove bracket located near the OPS, held on by two 14mm bolts. Its a support bracket connecting the Power Steering unit and Intake Manifold. You will need to remove it to fit the deep socket over the OPS
7. Remove OPS
8. Wrap the threads on the new OPS with Teflon tape. I did about three layers of tape on the threads
7. Install new OPS
8. Connect electrical to OPS
9. Mount support bracket
10. Install new oil filter
11. Fill engine with fresh oil
12. Start it up, check for leaks
It takes about 15-30 mins to change the oil and OPS. On a previous attempt to change the OPS I did not have a 1-1/16" or 26mm Deep Socket, and could not get enough leverage to budge the OPS with an adjustable wrench. Having the correct socket was a real time saver.
Sorry about the lack of pics, I need to get under the car this week to degrease the oil pan, I'll snap some pics then. Thats about it, hope this helps.....
Club MoFo Votary - My 200SX
Wufaded is offline   Reply With Quote
Oil change interval altima96gxe U13 1993-1997 Altima 6 Aug 28th, 2004 06:20 PM
03 Pathy Oil Change TRANsam Truck & SUV 1 Jul 21st, 2004 01:48 AM
Size of NPT fitting on oil pressure switch? Brainstorm GA16DE 1.6L Engine 2 Aug 22nd, 2002 07:39 PM
oil pressure switch or sending unit Manytoys SR-Series Engines (DE/VE) 7 Jul 31st, 2002 04:21 PM
Oil temp and Oil pressure gauges are done! PatScottAKA99XE GA16DE 1.6L Engine 2 May 5th, 2002 09:14 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
