Old Aug 6th, 2004, 09:21 AM   #1 (permalink)
cactusfarmer
RTV on head gasket install yes or no
I'm getting ready to install a new (used) head on my GA16. Am I correct in assuming I don't need to apply any type of gasket sealer/RTV on the new head gasket when I install it. Also, are there any tips or special cautions I need to watch out for besides what's covered in the FSM and Haynes Manual.
cactusfarmer is offline   Reply With Quote
Old Aug 6th, 2004, 06:15 PM   #2 (permalink)
wes
Wise Cracker
wes's Avatar
Send a message via AIM to wes
Do not use RTV on the gasket at all. The only recommendation I have is to make sure all surfaces are completely clean before assembly and make sure you use a torque angle meter rather than a torque wrench on the head bolts.
www.NissanPerformanceMag.com
JWT
www.notnser.com
Old Aug 6th, 2004, 10:27 PM   #3 (permalink)
cactusfarmer
Thanks for the tips. I guess I'm just going to have to poney up the bucks for a torque angle meter. Not sure what I'll ever use it for again, but I guess I have to have it to do this job right.
Old Aug 7th, 2004, 02:07 AM   #4 (permalink)
aminidab
Destroyer of Engines
aminidab's Avatar
wes, I'm curious why you would say a torque angle meter is needed. The FSM recommends it but dosen't say it's needed. I used a plain torque wrench when replacing mine and had no problems.
96 Sentra GXE
Boost is addictive
265WHP/257WTQ
aminidab is offline   Reply With Quote
Old Aug 7th, 2004, 09:08 AM   #5 (permalink)
wes
Wise Cracker
wes's Avatar
The first time I used a torque wrench I followed the specs. to a T. When I removed the head bolts to install a new head gasket the bolts were no where near where they should have been. The only true way to stratch them properly is with a torque angle meter, a torque wrench is just a close approximation and I am not going to guess with those bolts. Besides a TAM only costs about $25 anyway and you are sure the bolts are properly stretched when youa re finished.
JWT
www.notnser.com
Old Aug 7th, 2004, 10:11 AM   #6 (permalink)
cactusfarmer
Wes, after your first post about making sure to use a TAM instead of just a torque wrench, I've started digging around on the Internet trying to find one, of course there are many. Do you have any recommendation on what brand or type of TAM to get? Also, Iv'e never used one, are they pretty easy to figure out?
Old Aug 8th, 2004, 12:26 AM   #7 (permalink)
aminidab
aminidab's Avatar
Ah that makes sense, I didn't know it was that cheap to get a TAM. Since this is a realitivley cheap install (if you do it yourself), I'd get one if I had to do it again.
96 Sentra GXE
Boost is addictive
265WHP/257WTQ
Just replaced head gasket: Keep the car or sell? (kinda long) nickthegenius B11/B12/KN13 82-90 chassis 7 Jun 22nd, 2006 11:25 PM
Blown head gasket aminidab GA16DE 1.6L Engine 42 Feb 26th, 2004 08:45 PM
Leaking head gasket or cracked head... SuperHatch B11/B12/KN13 82-90 chassis 6 Nov 9th, 2003 01:33 AM
Resurfacing head for metal head gasket v8killer Forced Induction & Nitrous Oxide 1 Dec 7th, 2002 03:14 PM
Metal head gasket for 1.6 Urgent kartec Forced Induction & Nitrous Oxide 14 Nov 22nd, 2002 04:52 PM
