Old Jul 29th, 2004, 02:23 AM   #1 (permalink)
david328ci
What weight of oil do I need for an oil change?
Hi everyone,
This is my very first post. I recently purchased a 1999 Sentra GXE. It's time for an oil change and I was planning on using Valvoline Maxlife because the car has 85,000 miles on it.
I've used the search function, but I can't seem to find what weight oil the car uses. What weight oil is the best for the car? TIA
David328ci
- 1999 White Nissan Sentra GXE
- 2003 Alpine White BMW M3
david328ci is offline   Reply With Quote
Old Jul 29th, 2004, 03:05 AM   #2 (permalink)
black_ser95
cheese
black_ser95's Avatar
Send a message via AIM to black_ser95 Send a message via MSN to black_ser95 Send a message via Yahoo to black_ser95
i used to use 10w 30, but now i use 10w 40, eirhter one is fine
black_ser95 is offline   Reply With Quote
Old Jul 29th, 2004, 03:57 AM   #3 (permalink)
NotAnotherHonda
Have I Hit 12's Yet?
NotAnotherHonda's Avatar
i use 10w 40 on my turbo motor, and it works fine. so i figure, if that can be thick enough in my hot ass motor, its def. perfect for yours.
95 200sx se. sr20de, gt28r, bb manifold, forge fmic, greddy bov and bc, tial 38mm, walbro 255, apexi tt, 3" exhaust with magnaflow, 3" downpipe, jgy clutch flywheel and fuel rail, msd 50#'s, cobra maf, jwt ecu and s4's, nismo fpr, autometer, nissport adaptors, fal pushers, ur pulley, m/t 22x8x15 et drags.
NotAnotherHonda is offline   Reply With Quote
Old Jul 29th, 2004, 05:59 AM   #4 (permalink)
landlord
pay your rent!
landlord's Avatar
depending on where you live, but i think the recomended is 5w30 i use 10w30 as when the engine gets hots my vale guides start to leak.
95 200sx timing advanced to 15*, custom cai, Stromung exaust (no cat), b&m short throw shifter, rusted out fenders, worn suspension, creaking balljoints, cracked windshield and bad cv axles. your regular hooptie that requires 92 octane.
landlord is offline   Reply With Quote
Old Jul 29th, 2004, 08:10 AM   #5 (permalink)
Hendrix
What's in your wallet?
Hendrix's Avatar
Send a message via AIM to Hendrix Send a message via Yahoo to Hendrix
I'm using 5w30 with about 130,000 on my engine and no problems. Landlord is correct the manual calls for 5w30.
Hendrix
"Have you heard of the chain of command? It's the chain I beat you with until you realize that I'm in command" - Firefly, Jayne. Affirmative Action MoFo
Signature edited to please Scoot
Hendrix is offline   Reply With Quote
Old Jul 29th, 2004, 10:23 AM   #6 (permalink)
stealthb14
West Coast Redneck
Send a message via AIM to stealthb14
Mobil 1 Full Synthetic 10w30, car has almost 90K miles
Black 1997 Sentra GXE - Now Sporting : Hotshot CAI/15" Gunmetal Rota Subzeros/Eibach ProKit/KYB AGX's/Gen 2 Stealth Corners/more to come soon!
http://www.downshifitingischeating.com
stealthb14 is offline   Reply With Quote
Old Jul 29th, 2004, 05:32 PM   #7 (permalink)
stevja1
Slashie
stevja1's Avatar
Send a message via MSN to stevja1 Send a message via Yahoo to stevja1
Do you know if the car ran synthetic or regular oil before you bought it? I've heard that if you switch to synthetic after running regular oil for a long time, the seals may start to leak because the detergents in the synthetic oil remove all the grime that has become one with the seals. It probably isn't a big deal with your car though. Mines got almost 112k and I'm running Valvoline 5W-30 Synthetic Blend. Sometimes I switch to the same stuff, but the Quaker State kind.
Pretty much you'll want to run 5W-30 in the winter (if your winters are like northern Utah winters), and 10W-30 in the summer. You would probably be fine with 10W-30 all year round though.
'00 Sentra SE /w pp: Injen Intake : ES MMIs
Visit my website!
stevja1 is offline   Reply With Quote
Old Jul 29th, 2004, 06:10 PM   #8 (permalink)
psuLemon
i pwn your mom
psuLemon's Avatar
Send a message via AIM to psuLemon
its true, if you switch to synthetic after a long use of regular motor oil, seals will leak because sythetic will get rid of all the grime.. but then again, which rather you have a motor that last longer and runs better with sythetic and replace a seal here and there or run a regular and loose your motor faster.. i use 10w 30 mobil one
Originally Posted by hendrix
I can't wait until Hurrican Jamal sweeps up the east coast and steals the wheels and stero out of your car
psuLemon is offline   Reply With Quote
Old Jul 29th, 2004, 07:22 PM   #9 (permalink)
aminidab
Destroyer of Engines
aminidab's Avatar
There is an interesting article in the Sept 04 issue of turbo magazine about oil. First off it states the 'W' in oil grades stands for winter, not weight. A 5w30 oil flows like SAE 5 oil at cold temps(winter) and SAE 30 oil at operating temp.
From the FSM the recommended oil for the GA16 is:
5w30 for temps from -20 F or below to 100 F or above
10w30 for temps from 0 F to 100 F plus
The turbo article also recommends increasing the visocity one grade for turbo applications, so 5w40 or 10w40 for the GA16. There's also lots more useful info in the article.
Unfortunatly I can't find Mobil 1 in 10w40, so I'm going to try a blend of 10w30 and 15w50 for my next oil change.
96 Sentra GXE
Boost is addictive
265WHP/257WTQ
aminidab is offline   Reply With Quote
Old Jul 29th, 2004, 07:26 PM   #10 (permalink)
psuLemon
i pwn your mom
psuLemon's Avatar
http://www.sentra.net/tech/garage/en...d%20Lubricants
this is interesting
Old Jul 30th, 2004, 12:32 AM   #11 (permalink)
LIUSPEED
Vendor
DNE's VZR Conversion
LIUSPEED's Avatar
Send a message via AIM to LIUSPEED Send a message via MSN to LIUSPEED Send a message via Yahoo to LIUSPEED Send a message via Skype™ to LIUSPEED
mobil one full sythetic 10 W 30
LIUSPEEDTUNING.COM Get your new headlights,corners here !!
Click here to get great quality HID's here for a really good price!!
LIUSPEED is offline   Reply With Quote
Old Jul 30th, 2004, 09:19 AM   #12 (permalink)
Irons
Irons's Avatar
Send a message via AIM to Irons Send a message via Yahoo to Irons
I run Valvoline 5W-30 Synthetic Blend. The car has 135K on it. No problem with the oil. It's only had real or synth blend it. It gets cold in buffalo and it's never acutally hit 100 where the measure.
Irons.
96 GXE
93 Black SE. Parting out.
Irons is offline   Reply With Quote
Old Jul 30th, 2004, 02:29 PM   #13 (permalink)
david328ci
Thanks everybody. I think I'll go with the recommended 5w30.
David328ci
Old Aug 1st, 2004, 08:56 AM   #14 (permalink)
johnand
Nissan Fanatic
I've got almost 200K on mine, and I drive it hard so I use AMSOIL 15W-40 synthetic. I is a Euro spec oil.
1991 Sentra SE - Auto to Manual swap, 15" Rota Subzero's, 205/50 Kuhmo 712's, Tsuru headlight conversion, SE-R front and rear disc brakes, SE-R front and rear swaybars, SE-R throttle body, SE-R rear inner taillights, HS CAI and Header, H&R springs, Koni shortened struts, ES Hyperflex kit, B&M Short Shifter, Autometer gauges.
johnand is offline   Reply With Quote
Old Aug 1st, 2004, 08:27 PM   #15 (permalink)
PeaNutB13
Lurkshark........
Well down here in florida I use 10w30 maxlife and a half QT of Lucas Oil Stabilizer and I hardly have to add oil ever since I fixed the front seal. In my Civic I use 10w30 SYNTEC and a half QT of LUCAS Synthetic stabilizer. Damn I swear by the Lucas products. We'll see tho' I just ordered my Oil test kit. It's time to get tested.
PeaNutB13
My Nissan kicks Ass Yo!~
PeaNutB13 is offline   Reply With Quote
Changing Oil types ace B13 91-94 chassis 18 May 6th, 2006 10:10 PM
Need help diagnosing prob on 96 Pathy - oil or Trans fluid leak eric_c Truck & SUV 3 Jun 23rd, 2004 10:23 PM
Oil Change evvyone SR-Series Engines (DE/VE) 1 Jul 29th, 2002 04:07 PM
Where do you go for an oil change.. dschrier B11/B12/KN13 82-90 chassis 21 Jun 25th, 2002 11:57 AM
Transmission oil change kheimbuch SR-Series Engines (DE/VE) 2 May 30th, 2002 12:29 PM
