hector. alll aftermarket parts are off road use only... nismo1997, you cat is very high flow already, you might gain 1hp if you go with a high flow cat, but if you do, go with the random tech cat off the project 200sx 1.6T, you can PM jen@performance, its like 200... and obx is crap
Originally Posted by hendrix
I can't wait until Hurrican Jamal sweeps up the east coast and steals the wheels and stero out of your car
a gain of 10 hp is barely percetible. 1 hp is like you threw out all the trash in your car. you may gain flow but for you there are more restricting things than the cat in your car.
well if you are geting a high flow exhaust, why not get the cat with it 2? it wont hurt you. maybe it will be noticed on a dyno after a few other mods.
either way, there is other stuff you can spend your more on that will get more power, for 200, get an underdrive pulley from UR.. but if you are set on high flow cats, get the random tech one
everyone says how well the 1.6 cats are, but i have never seen one dyno chart of before and after....so be a first
if you look at a high quality hi flow cat and compare the guts to the OEM one its practically the same. the hi flow one may have less dense holes but not that much... so meaning you don't need to test it.
on a turbo engine removing or changing to a hi flow cat would make more sense.
i already got a catback but the place wanted 250 for a high flow cat..i told him i was good n ill leave the stock...mayb ill get some dyno's before n after..i gotta find a place here in ny to get it done
if i were you, ise just keep the stock cat on...savee your money and put it somewhgere else that has been proven to add more hppp...headers, intake, pulley, cams, ecu...etc
95 200sx se. sr20de, gt28r, bb manifold, forge fmic, greddy bov and bc, tial 38mm, walbro 255, apexi tt, 3" exhaust with magnaflow, 3" downpipe, jgy clutch flywheel and fuel rail, msd 50#'s, cobra maf, jwt ecu and s4's, nismo fpr, autometer, nissport adaptors, fal pushers, ur pulley, m/t 22x8x15 et drags.
