Old Jun 16th, 2004, 01:11 AM   #1 (permalink)
cooljamtransam
cooljamtransam's Avatar
Send a message via AIM to cooljamtransam Send a message via MSN to cooljamtransam Send a message via Yahoo to cooljamtransam
Exclamation help major problems on a 1993 Nissan Sentra XE
okay im posting for a friend that don't know much about cars but they drove it with one dead cylinder for a while and one day they went to start it and it sounded as if the engine had no compression yet it ran fine the day before. not sure what engine they have but i'll describe it so i can get better help for this engine
it has a double overhead cam run by a timing chain. 2 of them in the front 4 clynders.
#2 cylindar would not fire
I checked spark plug...was getting juice to cylander and was checked at distributor and it was firing, all others were firing great...but would not fire...susspected it was the fuel injector...car has 120,000 miles appx so this could happen...all of a sudden one morning when we tried to strat it the motor turned over very quickly with no compression and would not start... checked the chain, its not broken cams are moving...distrubutor turns...
by having driven it 3 months on 3 cylinders could that have caused this problem? and what is normal compression for cylinders in this engine?
cooljamtransam is offline   Reply With Quote
Old Jun 16th, 2004, 12:42 PM   #2 (permalink)
Nismo1997
Drop-Out
Nismo1997's Avatar
Send a message via AIM to Nismo1997
It could of, if the 1 cylinder is not firing its putting more stress on the other 3. when the spark fires it pushes it down and sends the other 1 up. after 3 months it took its last breath
Nismo1997 is offline   Reply With Quote
Old Jun 16th, 2004, 07:05 PM   #3 (permalink)
cooljamtransam
But do you have any idea what would cause a no fire in cylinder #2
Do You Have a Nissan More than 10 years old ? You are challenging Nissan...read Pablo14 General Discussion 34 Oct 18th, 2007 12:53 AM
A dealer and an independent tech can't eliminate erratic idle; HELP, if you can.... Pablo14 GA16DE 1.6L Engine 88 Nov 29th, 2004 12:30 PM
Cosmetic parts for 1996 nissan sentra R_E_D B14 95-99 chassis 0 Nov 8th, 2002 04:08 AM
