Old Jun 15th, 2004, 09:41 AM   #1 (permalink)
m_seats
m_seats's Avatar
Send a message via AIM to m_seats
Certain Way to Intall a Valve Cover Gasket?
I just ordered a valve cover gasket and i was wanting to know if there is any certain ways to put it in? I searched but really didnt find anything. I wanted to know if you have to use any type of liquid sealant along with it, or do you just remove the old gasket and put the new one in. Or do you have to put a little oil on the new one before installation. I dont know, just trying to do it right the first time. I dont want to mess it up and still have an oil leak. Thanks.
http://www.cardomain.com/memberpage/612537
m_seats is offline   Reply With Quote
Old Jun 15th, 2004, 10:01 AM   #2 (permalink)
NotAnotherHonda
Have I Hit 12's Yet?
NotAnotherHonda's Avatar
no special way. just take off the old seal, and place the new one in the groove.
95 200sx se. sr20de, gt28r, bb manifold, forge fmic, greddy bov and bc, tial 38mm, walbro 255, apexi tt, 3" exhaust with magnaflow, 3" downpipe, jgy clutch flywheel and fuel rail, msd 50#'s, cobra maf, jwt ecu and s4's, nismo fpr, autometer, nissport adaptors, fal pushers, ur pulley, m/t 22x8x15 et drags.
NotAnotherHonda is offline   Reply With Quote
Old Jun 15th, 2004, 12:58 PM   #3 (permalink)
m_seats
m_seats's Avatar
you dont have to put rub any oil on the gasket or anything?
Old Jun 15th, 2004, 02:24 PM   #4 (permalink)
lshadoff
Post Freak
lshadoff's Avatar
According to the FSM:
Lew
lshadoff is offline   Reply With Quote
Old Jun 15th, 2004, 03:15 PM   #5 (permalink)
m_seats
m_seats's Avatar
Lew
Thanks. I appreciate your time!!!
95 Sentra GXE: 17" Rota Sub Zero Rims, Falken Tires, Black Halo Projector Headlights, Black Stealth Crystal Clear Corners, Chrome Altezza Taillights, 4" Magnaflow Race Series Exhuast, Bomz Racing Air Intake, NGK Ignition Wires, Reverse Euro Glow Gauges, Front and Rear Strut Bars, Advanced Timing to 15 degrees, JL Audio Subs, Rockford Fasgate Amp
Old Jun 16th, 2004, 01:13 AM   #6 (permalink)
hector200sx
hector200sx's Avatar
Send a message via MSN to hector200sx Send a message via Yahoo to hector200sx
yeah thanks a lot have been looking for this i posted a while back about my valve cover and everyone thought i was just stupid i think. but i am haveing a hell of a time getting it to sea.l i think that i may have been useing too much sillicone. next time will be the 3rd try to seal it
hector200sx is offline   Reply With Quote
Old Jun 16th, 2004, 12:32 PM   #7 (permalink)
m_seats
m_seats's Avatar
The replacement gasket that i got is rubber and i think the old one is cork. Do i still do the same procedure or do i have to use the liquid sealant around the whole thing?
Old Jun 16th, 2004, 12:35 PM   #8 (permalink)
lshadoff
Post Freak
lshadoff's Avatar
The factory gasket is rubber. Cork is an aftermarket gasket, so you know someone has removed the valve cover in the past.
Use the procedure from the FSM above above.
Lew
Old Jun 17th, 2004, 09:50 AM   #9 (permalink)
sunnysentra
Nissan Addict
sunnysentra's Avatar
make sure you use liquid gasket of some type. I used grey RTF for imports. Permatex makes it. This is good to put around the distributor curve part. As shown on that picture above. Make sure you tighten the screws in the right number order. It will seal better. I used Locktight Blue on the screws for the cover to hold the torque better.
Chris 92 classic
Part of the AUTO / MANUAL SWAP CLUB
sunnysentra is offline   Reply With Quote
valve cover gasket hector200sx GA16DE 1.6L Engine 3 Jun 1st, 2004 11:04 PM
Valve cover gasket deformed, leaking oil? altima96gxe U13 1993-1997 Altima 3 Apr 23rd, 2004 09:59 PM
Valve Cover Gasket Replacement mr_wright1911 U13 1993-1997 Altima 1 Apr 13th, 2004 04:18 PM
SR20DE valve cover gasket leaks CrunchyCookie SR-Series Engines (DE/VE) 9 Jun 7th, 2003 04:37 PM
