Old May 16th, 2002, 03:41 PM   #1 (permalink)
simspektor
Posts: n/a
Oil Pan Removal 93 Sentra 1.6L...Help Please!!!
My wife hit something yesterday and punctured a hole in the oil pan. I have a new one coming and was under the car taking the damaged one out and got every bolt out except the last two on the transmission side. Seems the last two bolts are being overlapped by a cover or something on the transmission and it is impossible to get to them.
Can I take that cover off somehow? I don't have a manual to give me a clue.
How do I get those last two bolts out? I am broke and this is our only car. Please help me out folks! If you're ever in Columbus, Ohio I'll buy you a beer.
Thanks,
Steve
Old May 16th, 2002, 05:35 PM   #2 (permalink)
johnand
Nissan Fanatic
Those are actually nuts, and they hold the rear main seal retainer in there. You may have to lower or remove the crossmember to get enough clearance to pull the pan down enough to clear the studs of the rear main seal retainer. You cannot remove the rear main seal retainer w/o removing the transmission and flywheel!!!
1991 Sentra SE - Auto to Manual swap, 15" Rota Subzero's, 205/50 Kuhmo 712's, Tsuru headlight conversion, SE-R front and rear disc brakes, SE-R front and rear swaybars, SE-R throttle body, SE-R rear inner taillights, HS CAI and Header, H&R springs, Koni shortened struts, ES Hyperflex kit, B&M Short Shifter, Autometer gauges.
johnand is offline   Reply With Quote
Old May 17th, 2002, 02:32 AM   #3 (permalink)
Joshb13sentra
Send a message via AIM to Joshb13sentra Send a message via Yahoo to Joshb13sentra
I was able to get to them by supporting the transmision with a jack/block of wood and removeing the center cross member. Then I used a long 1/4" extension and a socket, it was a pain, but worked. Just make sure to scrape everything clean.
Joshb13sentra is offline   Reply With Quote
Old May 18th, 2002, 02:30 AM   #4 (permalink)
simspektor
Posts: n/a
Thanks for the advice. It's finished. The damn transaxle cover plate was so caked full of crap that I missed the pan support bracket hiding underneath the muck.
Did'nt have to remove the crossmember. Just removed the three exhaust pipe to manifold nuts and let that section hang down about 4 inches. The pan cleared the pickup with room to spare.
Thanks again.
Steve
Old May 22nd, 2004, 09:35 PM   #5 (permalink)
Winter
oil pan
Thanks again.
Steve
I just joined this forum and I was looking to see how to take off the oil pan and could not find a repair book at the store. I will try your way tommorrow and just remove the exhust . Did the bolts come off okay? Thank you Great job and good for you!
Winter is offline   Reply With Quote
leaking oil pan wolf New Member Forum 3 Jul 28th, 2006 03:59 PM
det oil pan Rottdog SR-Series Engines (DE/VE) 2 Jun 25th, 2003 09:50 AM
95 Sentra oil leak bmcneill GA16DE 1.6L Engine 4 Apr 21st, 2003 12:54 AM
Sentra oil pan removal WBarry E/CA-Series & GA16i Engines 3 Jan 13th, 2003 10:10 PM
