Old Jun 12th, 2004, 12:15 PM   #1 (permalink)
DuceDual0
Send a message via AIM to DuceDual0
EGR help!!!
aight, heres whats up, i was washing my car and i desided to clean the engine out too. now ive done this before many times and i just use simple green and the hose afterwards, the car was fine when i was finished and it ran great. then the problems set in. the next day i got in it and started to drive it and the car was lugging and idleing at like 2-300 rpms and thats not normal for me at all. i would get on it and the car would lag to get power out, an when i would let off the gas it would jolt and would speed up. now i thought that there might have been somthing wrong with the ECU, that wasnt the problem, then i took out a spark plug wire and found water in side the chamber, so i took them all out and let them air dry for a bit before i drove it again. when i drove it, it would drive fine for that period of time, i thought that water was shorting out the spark and it wasnt ingniting right, the next day it was lugging again and the check engine light came on, so i took out the ECU and did the self test to fine, 3 longs and 2 shorts, which came out to be the ERG valve malfunctioning. so i checked to see if the vacume hoses were on and they were but one was very britel and had a hole in it so i replaced it, the check engine light was still on so i checked for voltage to the EGR valve it self, it was fine so then i checked all the other vacume lines and they were fine but the one that was cracked that i had replaced, i looked in it again and found that it connectes to the bottom of the EGR valve and to a metal line, the metal line was full of some shit so i cleaned it out and tried to reset the ECU again but to no luck! plz some one help me i have ran out of ideas! thanks!
DuceDual0 is offline   Reply With Quote
Old Jun 12th, 2004, 02:47 PM   #2 (permalink)
psuLemon
i pwn your mom
psuLemon's Avatar
Send a message via AIM to psuLemon
what did you clean the egr valve with, they are very delicate and can break easier..
Originally Posted by hendrix
I can't wait until Hurrican Jamal sweeps up the east coast and steals the wheels and stero out of your car
psuLemon is offline   Reply With Quote
97 Pickup EGR problem viper2 Truck & SUV 11 Aug 30th, 2003 06:27 AM
EGR, Smog problems rallysentra GA16DE 1.6L Engine 2 Jun 20th, 2003 11:05 AM
EGR problems dookie GA16DE 1.6L Engine 1 Apr 30th, 2003 06:44 AM
Newb with an EGR problem... ArCerian GA16DE 1.6L Engine 8 Oct 30th, 2002 09:16 PM
EGR control valve...... qinsac SR-Series Engines (DE/VE) 6 Oct 11th, 2002 09:54 PM
