Old Jun 8th, 2004, 10:29 PM   #1 (permalink)
Mack
Mack's Avatar
Crankshaft Bearing...Help!
I know that there have been several posts regarding this question lately (inlcuding those of mine) but I have a more detailed question about it now. I do not know exactly how long the "knocking" vibration has occurred, but it doesn't happen every time I drive.
1) Could a "slightly" damaged bearing create a knock that comes and goes? (I realize that it still needs immediate attention, I am not driving my Sentra at the moment, either.) Or would a bad bearing create a constant knock?
Just to provide more details, the knock is a vibration that is noticable through the floorboard and is audible (dull and quiet, not a "click" from CV Joints). It feels as if it originates under the engine and occurs while driving straight, especially at higher speeds (it vibrates faster at higher speeds, too) and while turning. It can occur when I take a turn in neutral (clutch pressed) as well as when the throttle is applied. I'm trying to completely rule out what isn't causing the problem (CV Joints, suspension, etc) because getting the crankshaft bearing replaced will be over $1000 at a shop.
2) Could the manual transmission be to blame? The stick doesn't jump or bounce irregularly.
Thanks for any advice.
1993 Sentra XE
5 Speed 2 Door
Mack is offline   Reply With Quote
Old Jun 9th, 2004, 07:13 PM   #2 (permalink)
Mack
Mack's Avatar
Can someone lend any hints?
I really just wanted to know if a bad crankshaft bearing could make a vibration that is intermittent. My vibration/knocking doesn't occur all the time, so I just wondered if that would be a key towards determining what the problem is. Wheel bearings and the transmission could also cause a problem like this, I guess, so I'd like to isolate the effects.
1993 Sentra XE
5 Speed 2 Door
2001 GXE 1.8..Crankshaft and cam shaff sensor..error RHDV QG18 1.8L Engine 7 Jan 19th, 2007 01:57 PM
How to fix spun bearing? fugiot SR-Series Engines (DE/VE) 3 Apr 12th, 2004 08:37 PM
crankshaft pulley install shughes GA16DE 1.6L Engine 6 Sep 30th, 2003 08:34 PM
Wheel bearing or hub bearing... dschrier B11/B12/KN13 82-90 chassis 5 Oct 20th, 2002 09:34 PM
Will Nissan 60,000mi/60 month drivetrain warranty cover a throw-out bearing? PatScottAKA99XE General Discussion 4 Aug 27th, 2002 11:30 PM
