Old Jun 8th, 2004, 07:37 AM   #1 (permalink)
sunnysentra
Nissan Addict
sunnysentra's Avatar
Oil pan installation 1.6
Guys. I pulled the pan because of the leak. What gasket RTV did you use and did you use threadlock on the bolts? Also, should I I don't want the RTV to seperate inside and get sucked up into the motor. Maybe I will look in the manual, but it may not say.
Thanks Chris
Part of the AUTO / MANUAL SWAP CLUB
sunnysentra is offline   Reply With Quote
Old Jun 8th, 2004, 09:49 AM   #2 (permalink)
jer28
Nissan Fanatic
:sighs: ultra grey rtv is used from the factory (B14). I wouldn't reccomend using threadlocker on the bolts. If you use rtv then as you put the pan bolts in it will get covered in rtv and that will hold it in place very well indeed. The factory manual states to use about a 3.5 mm or so bead around the oil pan sealing surface and be sure to surround the bolt holes on the pan. The rtv will state on the package that it sets up in 1 hour and fully cures in 24 hours. So your safe after an hour. You will find more good information by searching, I know this for a fact...However I did answer your question but maybe next time try to give a quick search, these questions were straight forward and in the search.
jer28 is offline   Reply With Quote
leaking oil pan wolf New Member Forum 3 Jul 28th, 2006 03:59 PM
oil leak at pan or rear seal? sunnysentra GA16DE 1.6L Engine 5 May 26th, 2004 08:13 AM
oil leak in 94 sentra LE 1.6 fro98665 B13 91-94 chassis 2 May 18th, 2004 04:38 PM
Z10 Motorsports SR20 Aluminum Oil Pan Group/Buy QUiKSR20 SR20DE/DET Engines 5 Apr 8th, 2004 10:26 AM
N1 t/b and baffled oil pan group buy nismo-vzr Group Buys 0 Mar 17th, 2004 02:15 AM
