Old Jun 8th, 2004, 12:22 AM   #1 (permalink)
jharris1
Where is front main seal and how to replace it?
I am guessing it is in the area of the crankshaft pulley, but I am not sure where. I don't think the leak I have is coming from the oil pan. I just changed the oil today and drove from Jersey to Baltimore (about 100 miles), and sure enough after the car settled and the oil pressure went back down, there were oil spots on the ground. I'm not the most mechanically inclined but if someone knows where the seal is, can give specifics on how to get to the seal and what tools are needed, I can fix it.
93 Sentra E, came with nothing but power steering...
KYB AGX struts, Hyperco Gen 2 springs, Ebay FSTB, lots of 89 gas and TLC :)
jharris1 is offline   Reply With Quote
Old Jun 8th, 2004, 12:30 AM   #2 (permalink)
verno-dub
verno-dub's Avatar
Soon as you pull of the crank pulley you will see the front main seal. The seal is pressed into the timing cover. You just need basic tools to pull all the splash guards off. As for the crank pulley bolt, im forgot the metric size, sorry. I needed an impact to remove mine. You dont need an air impact gun, you can use an electric gun, although air is preferable.
verno-dub is offline   Reply With Quote
Old Jun 8th, 2004, 12:44 AM   #3 (permalink)
SentraFourplay
SentraFourplay's Avatar
32mm
been there done that, any problems just ask, very easy took me 40 minutes start to finish.
SentraFourplay is offline   Reply With Quote
Old Jun 8th, 2004, 08:23 AM   #4 (permalink)
jharris1
Okay so I guess that means pulling off the passenger wheel? Sounds straightforward enough.
Old Jun 8th, 2004, 08:37 AM   #5 (permalink)
jharris1
Also, will I have to drain the oil before I start?
Old Jun 8th, 2004, 03:03 PM   #6 (permalink)
SentraFourplay
I did an oil change at the same time, but I would recommend it
