Old Jun 7th, 2004, 10:51 PM   #1 (permalink)
RacinConcept
Send a message via AIM to RacinConcept
Brown motor oil...
When i changed my oil, it was brown and somewhat more creamy than regular oil should be. It this caused my overheating? I had a overheating incident earlier that day. I also ran my nitrous at tracks a few days earlier. Maybe a factor?
I change my Mobil 1 oil regularly every 3k miles fyi. Thanks for any info.
-Andrew-
1996 200SX 1.6L
-Place Racing Intake w/JWT filter
-15" Konig Helium Wheels/Toyo FZ4
-Tein S. Tech Lowering Springs/AGX
-Tsubo muffler w/ 2" catback
-Nis-Knacks H4 Headlights
-SR20DEvelopment Solid Motor Mounts
-Exedy Organic Racing Clutch
-Zex 55-shot Wet Nitrous Kit
RacinConcept is offline   Reply With Quote
Old Jun 7th, 2004, 11:04 PM   #2 (permalink)
lshadoff
Post Freak
lshadoff's Avatar
This could possibly be water in the oil. Usually this is a sign of a bad head gasket.
Lew
lshadoff is offline   Reply With Quote
Old Jun 8th, 2004, 12:33 AM   #3 (permalink)
verno-dub
verno-dub's Avatar
Lew
It's either that or the oil cooler coil in the radiator end tank is leaking coolant into the trans fluid. Check you coolant for oil also.
verno-dub is offline   Reply With Quote
Old Jun 8th, 2004, 03:03 PM   #4 (permalink)
jer28
Nissan Fanatic
Okay don't get me wrong I'd just like to try and understand. Verno, are you saying that a possible culprit of brown motor oil would be coolant leaking into the trans fluid? I don't know if the oil is cooled by the radiator (my old gm truck used to be), but certainly if the rad was cracked in that passageway it could allow coolant to mix with the oil. I'm curious to see if his oil is sooled by the radiator because that could be a suspect.
I'd like to guess on the headgasket thing, especially if you overheated it. Have you done a compression test yet? If thats the case you are in for some work. Take the head off (easier said than done, I know), have a machine shop resurface it and pressure test it. Have them pull vacuum on all your valves to see what kind of shape those are in.
Do a compression test...
jer28 is offline   Reply With Quote
Old Jun 8th, 2004, 03:23 PM   #5 (permalink)
sentra97gxe
OT's E-Referee
sentra97gxe's Avatar
Send a message via AIM to sentra97gxe Send a message via MSN to sentra97gxe
How does oil getting into the trans fluid affect the motor oil? Logically it would affect the tranny but I don't see where its affecting the motor oil. I may be wrong but just want to be sure of what you are talking about.
Mitch
My CarDomain Page
Originally Posted by psuLemon
I have a monkey that continues the post whoring through out the night. His next stop is Pete's house where i taught him how to judo chop cracka ass thugs
sentra97gxe is offline   Reply With Quote
Old Jun 8th, 2004, 07:52 PM   #6 (permalink)
RacinConcept
Well it must be the head gasket. Darn.
1996 200SX 1.6L
Old Jun 8th, 2004, 08:09 PM   #7 (permalink)
sno
**best avatar award**
sno's Avatar
my guess would the a blown head gasket.
sno is offline   Reply With Quote
Old Jun 8th, 2004, 11:29 PM   #8 (permalink)
verno-dub
verno-dub's Avatar
Red face
Sorry guys, I was thinking about the transmisson for some reason. My bad. Im a :dumbass: > I reread the post, and it seems like the headgasket, sorry for the confusion..
-verno
Old Jun 9th, 2004, 04:56 PM   #9 (permalink)
RacinConcept
Thanks for all the help guys. I just checked my coolant and theres a bit of oil in there. Talked to my mechanic friend, also said gasket.
Anyway, is changing the head gasket a diy thing, or should it be done prefessionally. A place i called quoted me $1000 for it. Whats a decent price?
-Andrew-
1996 200SX 1.6L
Old Jun 9th, 2004, 05:36 PM   #10 (permalink)
lshadoff
Post Freak
lshadoff's Avatar
It's fairly involved, but can be done in your driveway. The most important tool for the job is a Factory Service Manual. It involves draining the coolant, removing the intake conection, exhaust connection, timing chain cover, and cams, before unbolting the head. You might be able to do it in a week-end.
Lew
Old Jun 9th, 2004, 05:59 PM   #11 (permalink)
RacinConcept
Lew
I can do all that stuff, but dont trust myself enough to do it. Funny thing is, i trusted myself enough to install my nitrous, but cant take apart half my motor. I think i'll go to a shop. Thanks.
-Andrew-
1996 200SX 1.6L
Old Jun 9th, 2004, 07:23 PM   #12 (permalink)
sno
sno's Avatar
for $1000 i woulda had one of my car buddies come over and make a day out of it. it's amazing what you can get done when you bribe with beer.
but if it's above your abilities then going to a shop is probably the best thing. you don't wanna risk screwing something up and it costing you even more.
Old Jun 9th, 2004, 07:25 PM   #13 (permalink)
James
in^3,N20,RPM,PSI
James's Avatar
as long as the buddies aren't drinking WHILE work is being done on the car... never seen anything good come from that!
05 Frontier SE CC 4x4 (6spd)
Old Jun 10th, 2004, 12:10 AM   #14 (permalink)
himilefrontier
265k miles and counting..
himilefrontier's Avatar
Send a message via AIM to himilefrontier
It's not too difficult, just involved. Make sure that the head is not warped as this sometimes happens when you blow a head gasket. Also, why did it blow? Nitrous installed wrong? Bad waterpump that leaked enough coolant to overheat the engine? Bad fan relay or motor? Radiator plugged with dead bugs or other debris? I brutally overheated the KA24DE in my Frontier when the waterpump went and it did not blow a gasket. I overheated it so bad it quit running and the temp gauge was pegged at H, so I am very curious as to why it went.
1998 Nissan Frontier XE/2wd/5spd 1 owner, 264k miles
1985 Olds Cutlass, 350 Chevy, owned for 14 years
WANTED: 1968-1973 Datsun 510 or 1991-1994 Sentra SE-R
http://www.myspace.com/junkyardengineer
himilefrontier is offline   Reply With Quote
Old Jun 10th, 2004, 07:39 AM   #15 (permalink)
EhSteve
On some cars, the engine will shut down when it realizes it's getting too hot.
However, when I blew my gasket, it was because my radiator leaked out too much coolant, and the engine had no idea how hot it was getting. The coolant gauge was at C the whole time. Then the telltale white smoke and car no run no more.
On my girlfriends honda accord, she drove it for 6 months w/o an oil change, and had no oil left in the pan when we decided to take it on a trip on a hot day. The temp. gauge spiked, but the engine shut off and wouldn't let us start until it had cooled down. We limped it to a gas station and put in some oil, and it's been fine for ~5 years since then.
EhSteve is offline   Reply With Quote
james brown video... maxpower559 Off Topic 0 Apr 16th, 2004 01:11 AM
Brown Bread for sound damping in a B14 ebruceii B14 95-99 chassis 11 Nov 13th, 2003 12:05 AM
LMAO!!! You snooze, you lose...(not for the politcally disintersted) Marvin Off Topic 6 Oct 24th, 2003 09:42 AM
transmission issues (hard shift, brown , burnt) mk_sentra B13 91-94 chassis 3 Jun 25th, 2003 02:31 PM
Doo Doo brown interior t78silvia General 240SX/Silvia/S12 200SX 3 Mar 6th, 2003 06:01 PM
