so how do you check your fuel pump while on the car?
Also how can you check a used pump off the car before mounting?
I mean both mechanical and electrical tests.
I have sentra'92 it dies shortly after start I think fumes or small amount of fuel does that. Just ordered fuel pressure test kit but I need to know how to make sure I got a bad pump and how to check a used replacement from a yard
thanks
yeah I read about this test in a honda manual so I tried it on sentra earlier today I didn' hear anything and I check the voltage
there are two connectors at the pump after turning key on one is dead other shows I think about 7.5V
looks like a bad pump but I need to make sure
thanks
What is the size of a stock 93 sentra 1.6 fuel pump anyways? How much does it flow per min or hr? Im going turbo and need a bigger one, but I dont know what to upgrade to yet since i dont know stock size/flow.
