reset my ECU and turn the engine check light off successfully! - Nissan Forum
post #1 of 15 Old Jun 7th, 2004, 07:14 PM Thread Starter
Hi all,
I did reset the ECU on my 97 sentra gxe lst weekend. I am writing this to share my experience.
The engine check light came on after I start my engine without connecting the mass airflow sensor. It didn't go off even I reconnect the mass airflow sensor. I think it generated an error in ECU.
The solution is reset the ECU. Here is the right method.
http://www.sentra.net/tech/ecu.php?
It is a good article. The only thing that I want to mention here is that you need to do the screw method twice in a row to reset your ECU.
1.With the engine off, turn the ignition to the ON setting.
2. Turn the diagnostic mode selector on the back of the ECU fully clockwise.
3. Wait two seconds and turn the mode selector fully counter clockwise.
4. Turn the diagnostic mode selector on the back of the ECU fully clockwise.
5. Wait two seconds and turn the mode selector fully counter clockwise.
DO NOT turn on your engine between step 3 and step 4. That is the trick.
Btw, on my car, the disconnecting battery method didn't work well. I disconnected it for 4 to 5 hours while it didn't reset my ECU.
Hope this will help you. Thank you!
archer98
archer98 is offline
post #2 of 15 Old Jun 7th, 2004, 07:18 PM
in^3,N20,RPM,PSI
James's Avatar
now you know why searching is preached?
btw, between the first and second time you turn the screw fully ccw, you can look up at your dash and get the flashing code to find what caused the CEL to come on.
05 Frontier SE CC 4x4 (6spd)
James is offline
post #3 of 15 Old Oct 31st, 2005, 09:37 PM
This post was very beneficial for me! I was able to clear my codes easily. Thanks!
wheels_99 is offline
post #4 of 15 Old Oct 31st, 2005, 09:41 PM
What is Seven Ten for?
xbrandonx's Avatar
just so you know, if the problems aren't fixed and you just reset the ECU, be prepared for it to come back at you full force.
However, once a problem is fixed, the ECU will turn of the Check Engine Light after 3 times the car has been started and the ECU doesn't see the error.
Those who would give up Essential Liberty to purchase a little Temporary Safety, deserve neither Liberty nor Safety. - Ben Franklin
xbrandonx is offline
post #5 of 15 Old Nov 1st, 2005, 08:00 AM
Yea, I was reading about that as well. I was pretty sure these were just caused from me removing the distributor and turning it over while harness was removed.
I've started the car about 5 times now...I went for 2 10-15 minute trips and another 35 minute one this morning. The light has stayed off. Am I same to assume there are no codes there now?
post #6 of 15 Old Nov 1st, 2005, 10:47 AM
wes
Wise Cracker
wes's Avatar
Send a message via AIM to wes
More than likely. Honestly what you did should not cause that sensor to go bad, unless it just went bad at that time by coincidence. I would drive it as normal and just keep an eye out for a CEL. Now you can at least pul and check the codes yourself if you get one.
wes is offline
post #7 of 15 Old Nov 1st, 2005, 01:09 PM
Send a message via AIM to blackmaxima88
disconnecting the battery really isn't the way to go about it. I've heard that it had to be done for 24 hours, but even still, ECUs have capacitors and programmable memory that can retain the information indefinitely without power. it's the exact same thing as taking the battery out of your cell phone, and a few days later, you power it back up and nothing in the memory was wiped. the old battery trick might work on older cars but on these, where emissions is more of a concern, you're wasting your time.
like they said above, it can be done at the ECU, or if you have OBDII, you can use a scan tool.
Dan
"if you aren't really shifting, you aren't really driving."
blackmaxima88 is offline
post #8 of 15 Old Dec 29th, 2006, 09:14 PM
YES
YES...VERY USEFUL...you are the man. I shall now reset my ecu
....the story continues
smacktime is offline
post #9 of 15 Old Dec 29th, 2006, 11:08 PM
B13turbo93's Avatar
RESETY AT WILL
Completley gutted, Falken Azenis tires on black jax light wheels with 96 Ga16de block with 93 head loaded with 96 cams exhausting through stock pipe into Bassani muffler,and Exedy stage 1 clutch an pressure plate.
B13turbo93 is offline
post #10 of 15 Old Jul 11th, 2007, 08:27 PM
Avtomat Kalashnikov
Exalta's Avatar
Where is this ECU located? i checked behind the fuse panel in the interior and behind the center console but still cant locate it
Exalta is offline
post #11 of 15 Old Jul 11th, 2007, 11:31 PM
Destroyer of worlds.
Tavel's Avatar
Send a message via AIM to Tavel
it's on the floor under the dash, in the middle of the car, and directly behind the center console.
as for clearing the ECU with the battery...it does work depending on the car. The CEL was on in my 2000 corolla, I fixed the problem and unplugged the battery for 15 minutes and the CEL went out.
Unfortunately, the corolla doesn't have any way to pull the error codes manually like the sentra, so this is really the only option.
the battery thing did not work for my sentra either, i had to the manual reset...but I looked at the code first to make sure i actually fixed what it wanted.
I'll edit YOUR signiture!
Tavel is offline
post #12 of 15 Old Jul 12th, 2007, 08:45 AM
I Live Here
IanH's Avatar
the battery thing did not work for my Sentra either, i had to the manual reset...but I looked at the code first to make sure i actually fixed what it wanted.
disconnecting the battery worked on my Sentra, done it twice.
I also fixed an EGR problem ( replaced the little hose) and it took 15 days to go off by itself, car is driven daily for 11 miles each way.
2003 Pathfinder from 2004 SE 4WD
1997 SER 5sp Manual from new Rear Ended 2009 !!
Gone to the Knacker yard...
New ride 3.0 manual RWD not a Nissan !!! Gone 2016 from Hail damage.
1997 Sentra GXE from new .... Sold 2008
2001 Sunny N16 RHD from new (N16 Nissan Bluebird Sylphy) Sold
IanH is offline
post #13 of 15 Old Jul 12th, 2007, 05:54 PM
Nissan Fanatic
Send a message via AIM to oliverr87 Send a message via MSN to oliverr87 Send a message via Yahoo to oliverr87
clearing the codes does not solve anything if you actually DO have a faulty sensor or something.
oliverr87 is offline
post #14 of 15 Old Sep 1st, 2015, 04:21 AM
Very Useful nfo
Very useful ecu info. Will save countless hours. Much appreciated.
kotse is offline
post #15 of 15 Old Aug 4th, 2016, 04:14 AM
Question
2004 Nissan Sunny N 16. ( ex Singapore) The engine Malfunction Indicator Light is illuminated. Car is running rough and fuel consumption is poor. Any ideas on fixing this would be most appreciated.
Tiuminen is offline
Gear in this thread
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Linear Mode Linear Mode
HELP my Check engine light is on. bizzaro_thai Truck & SUV 12 Dec 9th, 2006 04:25 PM
Message from your friendly Moderator mastertech Truck & SUV 5 Nov 5th, 2004 03:05 PM
90 Nissan Hardbody check engine light on bertman123 Truck & SUV 2 May 24th, 2004 10:54 PM
Check engine light is on. Do I need to bring it in to Nissan to turn it off? psteng19 GA16DE 1.6L Engine 15 Dec 13th, 2002 09:03 AM
You may post new threads
You may post replies
BB code is On
