Old Jun 7th, 2004, 01:45 PM   #1 (permalink)
Kris_Schumacher
Problems with my 93 XE
I'm not sure, but I think I may have messed up my car. . . hopefully it's not a difficult fix, and someone knows what I did wrong. Here's what I did (keep in mind that as of this morning, my car was running beautifully:
I relocated the battery in the trunk, running 4ga wire from the original cable terminals in the engine compartment to a marine battery box in the trunk. I wanted to keep the orignal cables as is in case I need to change it back. After I did that, it seemed to run fine, although it seemed ever so slightly harder to start.
Then, I took off the MAF assembly (the big alluminum thing right before the air filter, right?) and painted it (just the outside, of course) with heat resistant annodized metal paint. I had to take it out of the car, so I unscrewed the sensor that was plugged into the top of it. I noticed that it only had 4 connection points, and that there seemed to be a place for a fifth. . . don't know if that's important. Anyway, I was careful about that, but when I reattached the assembly and the new cone air filter, the car won't stay running. It starts fine, but dies instantly. If I keep on the gas, it will stay, but the second I take my foot off the gas, it dies. Is the paint messing it up? What could be causing this?
Thank you for your help.
Kris
Kris_Schumacher is offline   Reply With Quote
Old Jun 7th, 2004, 05:32 PM   #2 (permalink)
sentra97gxe
OT's E-Referee
sentra97gxe's Avatar
Send a message via AIM to sentra97gxe Send a message via MSN to sentra97gxe
Dude you have to be ultra careful with the MAF sensor. That thing is real sensitive and not cheap to replace. What you're describing sounds like the MAF sensor not operating properly. It's my guess that you're gonna need to replace it. Hopefully someone else on here has better news for ya.
Mitch
My CarDomain Page
Originally Posted by psuLemon
I have a monkey that continues the post whoring through out the night. His next stop is Pete's house where i taught him how to judo chop cracka ass thugs
sentra97gxe is offline   Reply With Quote
Old Jun 7th, 2004, 09:36 PM   #3 (permalink)
EhSteve
you sure its grounded correctly?
EhSteve is offline   Reply With Quote
Old Jun 8th, 2004, 08:44 AM   #4 (permalink)
Kris_Schumacher
more details on problem.
OK, how do I check if it's grounded correctly? I assume I should unplug it and check the voltage on one of the pins, but I don't know what the trick is to unplugging it, which may have been part of my problem in the first place. The plug didn't want to come undone, so I unscrewed it at the base.
Anyway, here's an update.... This morning, I put the battery back under the hood, and it changed the symptoms a little. Now it doesn't die immediately, but it will not drive above 5 mph without surging, and there's no way I'm getting past 2nd gear. Sounds like the MAF, right? Or could it be that there is an air leak? I'll try putting back on the factory air filter, but I don't have high hopes.
Kris
Old Jun 8th, 2004, 09:30 AM   #5 (permalink)
Kris_Schumacher
MAF sensors on Ebay...
One thing: There's a MAF sensor on Ebay supposedly from a 94, but it doesn't look like mine. Does anyone know if this is the right part? If I could avoid paying $250 at autozone, it would be great.
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Kris
Old Jun 8th, 2004, 11:37 AM   #6 (permalink)
Kris_Schumacher
I think I may have figured it out!
I know that I was very careful with the MAF, so I really don't want to believe that it is that sensitive... I just took the whole assembly off and looked at it, and I think that I may have figured it out.
The MAF adaptor plate that I got from Autozone said on the back that it would work for 91-94 sentras, so I wasn't worried about it, but I had to drill new holes in the gasket to line up with the holes on my MAF... still, I didn't worry. Now, When I look at it, the gasket has a square opening that completely blocks any air from getting to the sensor, which is on the top of the pipe. I'm going to try enlarging the gasket to let the air flow to the sensor, and I'll keep you all informed. I have my fingers crossed.
Kris
Old Jun 15th, 2004, 02:11 PM   #7 (permalink)
krOnik
krOnik's Avatar
Send a message via AIM to krOnik
did u make sure
that u put the rubber O ring on?
1993 Nissan Sentra XE
http://www.cardomain.com/memberpage/526157
krOnik is offline   Reply With Quote
Old Jun 15th, 2004, 04:14 PM   #8 (permalink)
Kris_Schumacher
problem solved.
Yeah.... it's fixed now. The O ring was broken, but it wasn't the problem. I had to go through two MAF sensors before I found one that worked, but now it's running like new again (192k miles and it gets 40+ mpg on the highway) Those sensors are way too sensitive for my liking.
Old Jun 15th, 2004, 04:23 PM   #9 (permalink)
sentra97gxe
OT's E-Referee
Yeah, those things can be a pita since they are so sensitive. But you got it fixed. Good to here.
Mitch
My CarDomain Page
Problem/No Problems Zac QR25 2.5L Engine 69 Aug 25th, 2005 07:41 PM
97 Pathfinder steering problems. svneo Truck & SUV 14 Nov 4th, 2003 09:49 AM
sr20 problems evan717 New Member Forum 3 Jul 22nd, 2003 12:03 AM
03 spec V problems??? paint?? trans?? anything else?? Jeff22 B15 2000-2006 3 Dec 24th, 2002 06:47 PM
