Old Apr 22nd, 2004, 01:08 PM   #1 (permalink)
adrian76
Question GA16DE Timing issues
I think I may have messed something up. I recently did a tune up on my car and during the process of changing the rotor is where my problem started. My rotor was VERY difficult to come off. I should have took that as a sign to leave it alone, but being the hard-charger I am I continued. While forcing the rotor off, I heard some clicking (almost like gears) from the distributor. I wrote it off, but when I was done I checked the timing and needless to say it was off. Way off. I made adjustments and was able to get it back to stock 10 BTDC. I previously had it at 15 BTDC, now I notice a slight hesitation in the low RPM ranges. I back-probed the distributor to check the voltages and it checks out.
My question is...How do I start from scratch with the timing on the car, and should I replace the distributor anyway (the replacement rotor when on pretty rough, so I know it's going to be a bitch to get off!)? I've watched the Horsepower TV episodes and seen how they put piston 1 to TDC the insert distributor. Can I do that with my GA16? I know it's alot to swallow, but any help is appreciated.
adrian76 is offline   Reply With Quote
Old Apr 22nd, 2004, 01:27 PM   #2 (permalink)
James
in^3,N20,RPM,PSI
James's Avatar
Well are you sure you moved the rotor when you tried removing it? Do you get any pinging on hard acceleration?
If you can set #1 to TDC on the compression stroke, the rotor on the distributor should also be centered on the #1 post...
(someone check if I'm right, I've never made this mistake before so never had to do it! )
05 Frontier SE CC 4x4 (6spd)
Old Apr 22nd, 2004, 01:56 PM   #3 (permalink)
adrian76
Thanks, I'll try that.... I'm sure I moved it.
Pressure is something you feel when you don't know what the hell you're doing...
-Marine GySgt
GA16DE and variable valve timing RiceBox GA16DE 1.6L Engine 28 Mar 24th, 2008 06:15 PM
Advancing my timing issues 200sxOuTKasT GA16DE 1.6L Engine 22 May 20th, 2004 12:40 AM
hehe, quote of the day: Ninety-Nine SE-L Off Topic 20 Apr 6th, 2004 10:55 PM
ga16de advanced timing - how far to take it. darkelf Naturally Aspirated 6 Nov 14th, 2003 06:45 PM
GA16DE ignition timing tsi200sx B13 91-94 chassis 4 Feb 13th, 2003 08:19 PM
