» Site Navigation
» Other Sites
» Network Links
Apr 21st, 2004, 12:49 AM
#1 (permalink )
Throttle Body Q's
ok, i have a 92 sentra xe with the GA16 and auto tranny.
1. is there a difference between the TB on a auto and manual?
2. can the SR20 TB go onto the GA as easy as
this guy makes it seem, minus the whole TPS thing
3. and with the TPS thing, cant you just get the SR20 TB TPS, and wire into the GA16 TPS wires?
Sanity is the playground for the unimaginative.
Apr 21st, 2004, 10:36 AM
#2 (permalink )
Have I Hit 12's Yet?
i dunno about the other questions, but i do know that the sr20 TB will fit on a b13 1.6 with lil or no modification.
95 200sx se. sr20de, gt28r, bb manifold, forge fmic, greddy bov and bc, tial 38mm, walbro 255, apexi tt, 3" exhaust with magnaflow, 3" downpipe, jgy clutch flywheel and fuel rail, msd 50#'s, cobra maf, jwt ecu and s4's, nismo fpr, autometer, nissport adaptors, fal pushers, ur pulley, m/t 22x8x15 et drags.
Apr 21st, 2004, 11:24 AM
#3 (permalink )
FIVE SPEED&FOAM INJECTION
For the 2.0l you have to dremel out the plenum a little- put a rag in it before you start dremeling- thatll save you alot of problems.
ONE OF THESE DAYS I'LL FIGURE OUT HOW TO CHANGE MY WIPER BLADES
Apr 21st, 2004, 12:12 PM
#4 (permalink )
dremel where the intake hose meets the TB? or where do you mean
Apr 21st, 2004, 12:14 PM
#5 (permalink )
in^3,N20,RPM,PSI
Apr 21st, 2004, 12:30 PM
#6 (permalink )
and does anyone have a sr20 TB and HS CAI for sale?
Apr 21st, 2004, 03:48 PM
#7 (permalink )
Drifting is for amatures
i have a sr20tb for sale.
Apr 21st, 2004, 07:58 PM
#8 (permalink )
i cleaned my TB and noticed a world of difference, throttle response and low-end torque was back. i also looked at the TPS wiring, it looked like 3 wires, red white and blue, in that order from top to bottom. can anyone tell me what the wiring on the sr20 TPS is. thanx. and any ideas, comments, suggestions on the TB swap would be much appreciated.
Apr 21st, 2004, 08:00 PM
#9 (permalink )
in^3,N20,RPM,PSI
I haven't done the swap but I would try to take the tps off the ga tb and fit it on the SR one... if it fits then I don't think you have to screw around with the wiring. search for a user "johnand" and view his web page he has a picture of the swap done.
Apr 21st, 2004, 09:22 PM
#10 (permalink )
that is a good website, very imformative. missing 1 thing, the whole TPS thing. PM'ing now though
Apr 22nd, 2004, 02:46 PM
#11 (permalink )
what is the bore on the SR20 TB anyway? i know the GA16 is 30mm and you can bore it too 34mm
Apr 22nd, 2004, 02:48 PM
#12 (permalink )
in^3,N20,RPM,PSI
the ga is 50mm stock
I think the ser one is 54 mm stock.
Apr 22nd, 2004, 06:02 PM
#13 (permalink )
Wise Cracker
My O2 TB is 54 MM and the outside still fits inside the SE-R TB. The SE-R TB I have is 60MM.
Apr 22nd, 2004, 06:03 PM
#14 (permalink )
in^3,N20,RPM,PSI
There you go, 60mm...
man, it'd be nice to be able to make that work instead of just boring out the stock tb...
Apr 23rd, 2004, 12:56 PM
#15 (permalink )
If you are going to put on a new throttle body, then you've GOT to dremel out the intake manifold where it meets the throttle body if you want to have ANY noticable gain.
I am very skeptical of any gains from putting the a new throttle body on. The real restriction is at the filter. Additionally, if you increase the SIZE of the throttle body, then the velocity of the air that is coming in will probably be reduced. Again, I am VERY skeptical that such a throttle body is going to make a difference. The Nissan engineers did a very good job when they made the parts for that GA engine and I don't think tinkering with throttle bodies is going to make a noticable difference. It certainly won't be worth the time/money/effort it takes.
Linear Mode
