Old Apr 18th, 2004, 09:13 PM   #1 (permalink)
Nuskool
Right By DA Beach....
Nuskool's Avatar
Question Flywheel ?????
I was wondering if anyone has ever had any problems when they lightened there stock flywheel....I am only going to go like 10 lbs but am curious to what might go wrong when having a machine shop take off weight....
In the process...
Nuskool is offline   Reply With Quote
Old Apr 18th, 2004, 09:18 PM   #2 (permalink)
James
in^3,N20,RPM,PSI
James's Avatar
the flywheel could explode....
05 Frontier SE CC 4x4 (6spd)
Old Apr 18th, 2004, 09:31 PM   #3 (permalink)
NismoPC
Nissan Fanatic
True! So true!
Why in the world do you think you can get a stock flywheel down to 10 lbs safely, and what reputable machine shop would do such a dumbass thing?
Shaving that much of the flywheel off will weaken the overall integrity of the metal and KABOOM! Crash! Boom! Bam! Say good by to your clutch, flywheel, pressure plate and possibly even your tranny and casing.
Brandon
'96 G20 (modified)
NismoPC is offline   Reply With Quote
Old Apr 18th, 2004, 09:32 PM   #4 (permalink)
se-r-57
Nissan Fanatic
Send a message via AIM to se-r-57 Send a message via Yahoo to se-r-57
There is no way you can lighten a stock flywheel that much safely. Ya ever see what happens when one explode's?
94 se-r saphire blue with lot's of crap
I'm just a monkey. I don't know shit.
In the white SE-R when the AMG benz did the ricer fly by on 408 :)
se-r-57 is offline   Reply With Quote
Old Apr 18th, 2004, 09:34 PM   #5 (permalink)
Harris
Super-Mod with a 240
Harris's Avatar
Send a message via AIM to Harris
There is a reason why there are light flywheels made by aftermarket companies. Do it right the first time or regret your mistake to eternity.
"The greatest trick the devil ever pulled was convincing the world he didn't exist".
-The Usual Suspects
Harris is offline   Reply With Quote
Old Apr 19th, 2004, 12:15 AM   #6 (permalink)
200sxOuTKasT
200sxOuTKasT's Avatar
Isn't Wes running an oem lightened flywheel down to 11lbs with his 250 whp 200sx? I can't check anymore cause his website at www.wes.nissanpower.com is down, but I'm pretty sure thats what it said before.
91 240sx
98 200sx SE (Long gone...)
My 200sx Timeslips as of 04/11/04
Injen Short Ram Intake, custom 2" mandrel bent piping, Magnaflow muffler
200sxOuTKasT is offline   Reply With Quote
Old Apr 19th, 2004, 09:18 AM   #7 (permalink)
sfhellwig
Nissan Fanatic
I was going to bring this up if someone hadn't already. The last time I read Wes' page yes he was running a lightened stock flywheel. However he may have changed it but have never seen it stated on his page. Having said that I'm sure it's one of those exceptions to the rule. Wes must have gotten a good flywheel. The inconsitency of the metal is what started the initial scare. I read once you could take a box of our flywheels and try to bend each one in half. Some would bend easily and some not at all. Problem is, how do you know which one you have on your car. You could probably do 4-5 lbs. safely but to go to the weight you want it would probably break before they finished shaving it. However, I have no personal experience with flywheels beyond what I have read.
too poor to enjoy.....
sfhellwig is offline   Reply With Quote
Old Apr 19th, 2004, 09:21 AM   #8 (permalink)
sfhellwig
Nissan Fanatic
Regardless of everything I said in the previous reply: the flywheel is not a place to be messing around. Wether you go aftermarket or modified stock, make sure you are confident in what you're doing and be ready to take responsibility for what happens. If that thing explodes you could be dodging shrapnel thrown at 7000 rpm.......at YOU.
Old Apr 19th, 2004, 09:22 AM   #9 (permalink)
James
in^3,N20,RPM,PSI
James's Avatar
Don't take off more than 1/3 of the weight of the wheel... stock ga's flywheel is 18lbs so don't go below 12.
Old Apr 19th, 2004, 10:49 AM   #10 (permalink)
wes
Wise Cracker
wes's Avatar
Send a message via AIM to wes
I have had mine at 11 lbs. for over 3 years without issue. It was lightened by a world class rally shop that removed what they could without taking off too much material. It has held time and again although it is starting to wear so I will eventually replace it with an aftermarket one. I did this when the only GA flywheel was the $400+ UR piece.
www.NissanPerformanceMag.com
JWT
www.notnser.com
Old Apr 19th, 2004, 01:10 PM   #11 (permalink)
dookie
i had mine taken down to 12lbs. i have had it done for a year now and haven't had any problems. i have even dropped the tranny twice, once due to a broken shift fork and another time because of a broken differential, and it still looks fine. not bad considering it only cost me $60 to lighten it.
hs hdr, hs cai, 2" crush bent catback, ad22vf brakes, es motor mounts, gc/agx coilovers, ps short shifter, jdm heads/corners
dookie is offline   Reply With Quote
Old Apr 19th, 2004, 04:32 PM   #12 (permalink)
Nuskool
Nuskool's Avatar
Thats why i said I was curious...Thanks guys for the replies....Now that I have the ACT clutch sitting in my house..I guess im going to hold out because I have not found anyone to lighten it....The cheapest I have found is the findanza for is $358
and yes harris double posting is stupid I agree 100%...I just only wish my computer worked like fined tunned AUTOMOBILE...Sorry Harris thought we where cool and that I was being funny guess I kind of hurt some fealings sorry.....
In the process...
Old Apr 19th, 2004, 06:05 PM   #13 (permalink)
Katana200sx
P.O.S. Truckdriver
Katana200sx's Avatar
Send a message via ICQ to Katana200sx Send a message via AIM to Katana200sx
i have a 8lb clutchnet flywheel in my car right now. only downside is it cant be resurfaced...you have to replace the friction plate. it was $280 shipped in the groupbuy on the sr20forum
Katana200sx is offline   Reply With Quote
Old Apr 19th, 2004, 07:19 PM   #14 (permalink)
Nuskool
Nuskool's Avatar
ok what about the findanza can those flywheels be resurfaced...
In the process...
Old Apr 19th, 2004, 09:14 PM   #15 (permalink)
James
in^3,N20,RPM,PSI
James's Avatar
think they need to replace the ring as well...
flywheel choice chwwilliam S13 240SX 1989-1994 2 Sep 21st, 2003 09:00 AM
flywheel 91NX2000 New Member Forum 1 Aug 31st, 2003 10:06 AM
findanza flywheel owners please read Nico Flax GA16DE 1.6L Engine 9 Aug 19th, 2003 10:45 AM
Clutch trouble, please help Nico Flax B14 95-99 chassis 16 Jun 20th, 2003 10:56 AM
