Old Apr 9th, 2004, 09:20 PM   #1 (permalink)
NewbieNX
Temp Sending Unit Location
I need to know the temperature sending unit location on my 90 Pulsar. I have already replaced the coolant senser. So any help would be appreciated.
Chuck
Like a Burrito From Taco Bell, This Too Shall Pass :thumbup:
NewbieNX is offline   Reply With Quote
Old Apr 10th, 2004, 11:42 AM   #2 (permalink)
new94
Nissan Fanatic
if it's the GA16DE then it's just under your distributor hidden a little, it's a small brass nipple type thing that threads into the engine. It has a single wire going to it, if you have the new one ready then you can quickly switch them without losing alot of coolant only a small stream will come out but make sure the car is cold! My guage quit working so i replaced the temp sensor and it's fine now, good luck.
new94 is offline   Reply With Quote
Old Apr 10th, 2004, 02:31 PM   #3 (permalink)
NewbieNX
I dont know if theres a difference I have GA16 not sure on the DE I think its the I. but I am sure going to check. Thanks
Chuck
Temp Switch NewbieNX B11/B12/KN13 82-90 chassis 0 Apr 6th, 2004 03:36 PM
JDM vs USDM oil sending unit? 1fastser Forced Induction & Nitrous Oxide 2 Apr 7th, 2003 12:17 PM
Questions on head unit output wattage Andro Audio 8 Jan 7th, 2003 10:24 PM
About this 5th gear poping out... deejays B13 91-94 chassis 12 Nov 11th, 2002 09:52 AM
oil pressure switch or sending unit Manytoys SR-Series Engines (DE/VE) 7 Jul 31st, 2002 04:21 PM
