Knocking noise from engine - Nissan Forum
post #1 of 10 Old Mar 22nd, 2004, 08:46 PM Thread Starter
Ive been hearing a knocking noise lately from the engine bay when im accelerating and i was just wondering if anybody had any ideas on what it could be. It happens in all gears and is mostly at low rpms. I have an intake but it made then noise before i put it on so... any ideas. Thanks.
Inspectadeck24 is offline
post #2 of 10 Old Mar 22nd, 2004, 09:52 PM
same exact proble, isnt it more of like a rock in a coke can? like a metallic clinging? i want to know this also
Triple_T is offline
post #3 of 10 Old Mar 22nd, 2004, 10:10 PM
Classic XE's Avatar
Im having a clacking noise when I shift and accelerate. Its my motor mounts.
David
93 SE-R Classic!
Classic XE is offline
post #4 of 10 Old Mar 23rd, 2004, 03:53 AM
Haveing a knocking prob too! It seems like its right under the valve cover where the timing chains are. Is it the tentioner?? Its pretty worn... I am doing a Rod bearing job, Changing the timing chain tentioners and going through the head. Is there anyhting else inside the engine that can cause a knocking that only seems to happen when I let off the gas slightly at about 2800-3200 RPMS??????
nathanklein is offline
post #5 of 10 Old Mar 23rd, 2004, 04:17 AM
Proud owner of a GA16i
Galimba1's Avatar
Send a message via AIM to Galimba1
Hows your oil level? This happened once in my car. It was valve slap due to lack of oil (Major oil leak from loose crank pulley). When I topped the oil level off, the sound went away.
Galimba1 is offline
post #6 of 10 Old Mar 23rd, 2004, 10:30 AM
Destroyer of Engines
aminidab's Avatar
I had a knocking/clacking sound coming from the timing chain area. I believe it was due to the timing chain, the upper one was eating through the lower cover. I've replaced the timing chains and the tensioners, but I haven't started the engine yet to be sure that fixed the problem.
After taking everything apart, I believe this was caused by the upper timing chain tensioner being siezed.
2008 BMW 135i
96 Sentra GXE
Boost is addictive
265WHP/257WTQ
aminidab is offline
post #7 of 10 Old Mar 23rd, 2004, 10:58 PM
aminidab's Avatar
Just an update, replacing the timing chains/tensioners fixed the problem.
2008 BMW 135i
96 Sentra GXE
Boost is addictive
265WHP/257WTQ
aminidab is offline
post #8 of 10 Old Mar 24th, 2004, 07:32 PM
fuel
I think you got the wrong fuel in your engine. Sounds to me like its detonating. Put 91 octane in there. Works really good for me.
stylinnprofilin is offline
post #9 of 10 Old Mar 24th, 2004, 09:15 PM
High times
Dwntyme's Avatar
Speeking of timing chains. when I took my wifes GXE in for a recall I was talking to a tech about buying an Alti he said get the one with the V6 because they have had issues with the 4 banger's timing chain making noise. AKA. QR25's timing chains.. I said "humm really what about the specV" and he was silent....
WARNING:Wastegates,Blowoff Valves,and Boost Controllers can cause unforseen urges to crap your pants.
93 Nissan Hardbody**SOLD**
03 White SpecV(GONE)
Now 06 Mustang GT
Dwntyme is offline
post #10 of 10 Old Mar 24th, 2004, 09:17 PM
High times
Dwntyme's Avatar
But he did say that the trouble they are having is that the drains from the tensioner and takes a while to prime back up to put proper tension on the chain.
Now 06 Mustang GT
Dwntyme is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
Instructions and the step by step of swap BobbyRay S13 240SX 1989-1994 47 Dec 22nd, 2003 11:09 AM
Bad Gas Mileage 1997XETruck Truck & SUV 48 Sep 5th, 2003 03:35 PM
noise in the engine bay snkee200sx GA16DE 1.6L Engine 9 Aug 10th, 2003 01:51 AM
clicking engine noise nismosentra GA16DE 1.6L Engine 3 Feb 3rd, 2003 10:20 PM
knocking when warm yarikoptic GA16DE 1.6L Engine 10 Oct 22nd, 2002 12:22 PM
You may post new threads
You may post replies
BB code is On
