Old Mar 10th, 2004, 09:15 AM   #1 (permalink)
Pat200sx
Resident Raider Fan
Pat200sx's Avatar
Send a message via AIM to Pat200sx
need alittle help
ok First off i drive a 1996 200sx, and last night while i was driving it i noticed something
I'd take off (not pushing hard at all on the car) get into second and while going thorugh second decide to give it alittle gas... when i do this the car didn't seem to accelerate very fast at all and the rpm needle just kinda "flowed" thorugh the numbers and the engine just raced... i then put it into 3rd... had no problem with normal excelleration but when i would try to push it hard it would do the same thing.
Has my clutch just shit the bed?
Thanks,
-pat
GA16de
Stromung Cat-Back Exhaust, Injen Short Ram Intake, Lucino grill, Se-r rims, Toyo Proxes tires
Originally Posted by MrEous
Pancake titties...FTL
Pat200sx is offline   Reply With Quote
Old Mar 10th, 2004, 09:17 AM   #2 (permalink)
Pat200sx
Resident Raider Fan
Pat200sx's Avatar
Oh and while i was driving it, it did that beeping noise that the car goes when you shut off you car and forget ot turn your lights off. It did that while i was driving... (scared the crap outa me)
GA16de
Old Mar 10th, 2004, 01:34 PM   #3 (permalink)
Pat200sx
Resident Raider Fan
Pat200sx's Avatar
And if it is the clutch.....
How much does it usually cost to get another put in?
GA16de
Old Mar 10th, 2004, 02:09 PM   #4 (permalink)
Harris
Super-Mod with a 240
Harris's Avatar
Send a message via AIM to Harris
It sounds like the clutch is slipping. Labor for that can be nuts, so try to find a friend or someone from the forum who can help you. The actual clutch assembly itself should cost you no more than $130.
"The greatest trick the devil ever pulled was convincing the world he didn't exist".
-The Usual Suspects
Harris is offline   Reply With Quote
Old Mar 11th, 2004, 10:26 PM   #5 (permalink)
'98200SXse
Send a message via AIM to '98200SXse Send a message via Yahoo to '98200SXse
I know alot of people are gonna give me hell over this, and that I should seach, but what all is involved in replacing the clutch? I've got the same symptoms mentioned above, i'm not asking like so much about the procedure to replace it, just the replacement stuff, gonna have to go see how much that will run me, just what parts do i need? plus i've had recommendations from Samo to get an ACT or a JWT.... but those are pretty pricey, how about clutchmatsters or something else??????? just want to get the car back to normal running.
'98200SXse is offline   Reply With Quote
Old Mar 12th, 2004, 02:14 AM   #6 (permalink)
ReVerm
Boxed Fox
ReVerm's Avatar
Well, I know people are going to yell at me for saying this, but if you don't have a lot of modifications the stock Nissan clutch is really pretty good. You can get the stock disc for about $43 from Courtesy Nissan. As for what parts you will actually need (besides the clutch disk itself), you will have to see what else (if anything) is damaged/shows wear. You will probably need to get the flywheel resurfaced, but other than that, you normally don't need to do too much more. For a specific list of tools you'll need, I suggest looking at the B14 FSM listed in the sticky at the top of the B14 section. Good luck.
Captain Slow.
HALO vs. PROJECTORS blowing off alittle steam. FatBoy4 Cosmetic Mods 8 Mar 4th, 2004 12:08 PM
I need alittle info on 300z turbo cars. 87200sx Z31 300ZX(T) 1 Mar 17th, 2003 12:57 AM
is there a complet turbo kit or do i have to buy alittle from everyone RyanSnow SR-Series Engines (DE/VE) 6 Feb 7th, 2003 01:52 PM
