Old Mar 1st, 2004, 11:08 PM   #1 (permalink)
I'm tired of my usernamee
Soggy GloryHoler
I'm tired of my usernamee's Avatar
Send a message via MSN to I'm tired of my usernamee
Unhappy Huge wiring problem!!!!!!!!!!!!!!!!!!!!
I was dropping my dad off and then i smelled something burning. As i pulled into a parking space, smoke was coming out of the hood. We found out that a wiring harness and a black wire had burnt out. This was the one that is on the assembly that attaches to the MAF and so forth. I was wondering if anyone has ever had this happen? If so what did you do to fix it. I am hoping its not too severe and was also wondering if i could just pull out the wiring harness and replace it. Also everything that runs off the battery is fine, its just nothing involving the engine will work. The plug thing at the end of the loose harness is melted! Please help!!!!!!!!!!Also i noticed Matrix021 had the same problem. Did he ever get the problem fixed? If so how did you do it?
I'm tired of my usernamee is offline   Reply With Quote
Old Mar 3rd, 2004, 04:03 PM   #2 (permalink)
Matrix021
Matrix021's Avatar
Send a message via AIM to Matrix021
WOW... I'm not the only one... I was about to ask you if it's the same prob I had, then you mentioned me... so to give you an update, the car is in the shop... I took it to an auto electric place, not just some regular mechanic... I haven't talked to the lead electrician yet, but I did talk to the front desk person. So far, the wire needs to be repaired and I believe that thing on the end (apparently some sort of diode) needs to be replaced. I don't have the costs yet. And I don't have a reason yet. The guy will get off lunch soon... as soon as I know, I'll give you all the nasty details...
And that's my 2 cents....
Matrix021 is offline   Reply With Quote
Old Mar 5th, 2004, 03:56 PM   #3 (permalink)
Matrix021
Matrix021's Avatar
Aye... I'm posting the info on my thread if you wanna know what happened...
http://www.nissanforums.com/showthread.php?t=48819
SR wiring problem with head lights innes177 SR20DE/DET Engines 6 Feb 27th, 2004 01:18 PM
huge electrical problem HELP ME!!!!!!! nissan1 B14 95-99 chassis 2 Oct 26th, 2003 11:57 AM
wiring problem andypnice SR20DE/DET Engines 6 Sep 18th, 2003 05:53 PM
wiring problem nong B14 95-99 chassis 6 May 19th, 2003 05:50 AM
wiring problem cholojr19 S13 240SX 1989-1994 1 May 5th, 2003 07:23 AM
