Old Mar 1st, 2004, 08:20 AM   #1 (permalink)
psr
Banned
psr's Avatar
Intake gasket?
for some reason my car seems to be running really bad. the 1 and 4 cyl have too much fuel going to them (when i take out the spark plug fuel is dripping off) while the 2 and 3 cyl are running so lean the plugs are almost all white. i did remove the intake, so i was wondering if maybe i put the gasket in wrong? in all the books have about the sentra that i have it says theres a good chance i have a vaccume leak or intake leak. just wondering if any one could agree or disagree.
psr is offline   Reply With Quote
Old Mar 1st, 2004, 09:38 AM   #2 (permalink)
dreadsword
Nissan Fanatic
dreadsword's Avatar
Did you get the injectors,plug wires, etc all back in the correct order when you reassembled everything?
dreadsword is offline   Reply With Quote
Old Mar 2nd, 2004, 07:42 AM   #3 (permalink)
psr
Banned
psr's Avatar
yes
Old Mar 2nd, 2004, 10:18 AM   #4 (permalink)
NotAnotherHonda
Have I Hit 12's Yet?
NotAnotherHonda's Avatar
maybe the o-rings on the injectors slipped off...you took OFF the injecotrs, right? if not, i dunno what i could be
95 200sx se. sr20de, gt28r, bb manifold, forge fmic, greddy bov and bc, tial 38mm, walbro 255, apexi tt, 3" exhaust with magnaflow, 3" downpipe, jgy clutch flywheel and fuel rail, msd 50#'s, cobra maf, jwt ecu and s4's, nismo fpr, autometer, nissport adaptors, fal pushers, ur pulley, m/t 22x8x15 et drags.
NotAnotherHonda is offline   Reply With Quote
Old Mar 3rd, 2004, 08:45 AM   #5 (permalink)
psr
Banned
psr's Avatar
nope, i didnt have to take out the injectors when i removed the intake
Old Mar 9th, 2004, 07:59 AM   #6 (permalink)
psr
Banned
psr's Avatar
well i found out that its not the intake gaskets. so i was wonder if someone could tell me whats wrong.
1. the compression is messed up or maybe its the gauge.. 1cyl 210psi, 2cyl 160psi, 3cyl 110psi, 4cyl 210psi
2. the car ran good for about a day after i changed the head gasket so i didnt put the cams in wrong. then after that day it would start but i took about a minute of constant turning over.(plus when i took out the plugs the #1and4 cyl where dripping with fuel while #2and3 cyl where running lean.) then the next day it wouldnt even start.
3. im getting spark to all the spark plugs i checked that.
4. im getting enough fuel in the car. the plugs are dripping with fuel when i take them out. plus theres fuel in the oil.
5.it turns over but dosent start.
6. i changed the o2 sensor
well there you go thats whats wrong with my car so if anyone knows whats going on please fill me in. oh yeah i did hook up all the vaccume lines correct i checked them all twice.
Old Mar 9th, 2004, 08:30 AM   #7 (permalink)
jer28
Nissan Fanatic
It almost sounds like your not getting spark, verify that you are. The plugs could be wet due to no spark. Also I have only done head gaskets on cars with timing belts, but during your head gasket did you have to remove the timing chain (probally). Maybe it somehow either jumped timing or is not set correctly. Just some suggestions...
jer28 is offline   Reply With Quote
Old Mar 9th, 2004, 08:43 AM   #8 (permalink)
psr
Banned
psr's Avatar
well i did check each spark plug and there all working. i guess im left with taking the timeing chain cover off and checking to see if the cams are lined up correctly.
thanks for your help
New ga16i intake options!!! 89PathSE GA16DE 1.6L Engine 5 Jun 29th, 2006 06:03 AM
New ga16i intake options!!! 89PathSE B11/B12/KN13 82-90 chassis 56 May 27th, 2004 01:49 PM
Custom Intake glowsentra B13 91-94 chassis 21 Aug 19th, 2003 06:10 AM
My intake. trannyfilterproblems B13 91-94 chassis 0 Mar 23rd, 2003 02:26 PM
1.6L sentra air intake questions smithsil Naturally Aspirated 14 Sep 18th, 2002 10:38 AM
