Old Mar 1st, 2004, 03:23 AM   #1 (permalink)
ga16denismo
Need EGR Help!!! Fast!!!
Ok, well here's the situation. I'm due for a smog check and when I go, I pass all the tests but one. I do have a modified exhaust, but it's pretty much what a lot of the members here have (4-2-1 header to cat to 2in piping to muffler). For some reason the EGR is reading too high. Please someone help me figure this thing out (did I mention I live in California). Need to be done really soon. Has anyone else had problems with passing smog with this highly recommended setup?
Will work for parts...
Need Car Audio Stuff? Let me know...
ga16denismo is offline   Reply With Quote
Old Mar 1st, 2004, 06:10 AM   #2 (permalink)
Harris
Super-Mod with a 240
Harris's Avatar
Send a message via AIM to Harris
What do you mean by the EGR reading too high? Are your NOx numbers way up? Please provide more details.
"The greatest trick the devil ever pulled was convincing the world he didn't exist".
-The Usual Suspects
Harris is offline   Reply With Quote
Old Mar 1st, 2004, 11:23 PM   #3 (permalink)
ga16denismo
Exactly, my NO numbers are pass the max for California Emissions.
Old Mar 1st, 2004, 11:28 PM   #4 (permalink)
Harris
Harris's Avatar
In that case, you need to clean the EGR system, as dirt collecting in it over time makes it inefficient.
OR,
Take your ignition timing down to like maybe 5* BTDC. That should help lower your NOx numbers. Hopefully your HC and CO emmissions won't go up dramatically because of that.
I think I'm right. Man, I hate emmissions check. I know Cali is just nuts when it comes to that. Good thing I'm in Ohio, where its not as nutsy as your state.
-The Usual Suspects
Old Mar 2nd, 2004, 01:27 AM   #5 (permalink)
sno
**best avatar award**
sno's Avatar
i thought running high NO numbers meant you were running lean.... i'm just guessing tho.
sno is offline   Reply With Quote
Old Mar 2nd, 2004, 09:09 AM   #6 (permalink)
Harris
Harris's Avatar
Yes. Lean = hot = higher NOx, which is why I told him to retard his timing.
-The Usual Suspects
Old Mar 2nd, 2004, 10:08 AM   #7 (permalink)
OmegaManEX
Work With What You Got
OmegaManEX's Avatar
Send a message via AIM to OmegaManEX
Originally Posted by ga16denismo
Ok, well here's the situation. I'm due for a smog check and when I go, I pass all the tests but one. I do have a modified exhaust, but it's pretty much what a lot of the members here have (4-2-1 header to cat to 2in piping to muffler). ...
im just curious .. you pass visual with the header and and the cat relocated?
B14 200sx: GA16DE at 15º BTDC + HS CAI + stromung cat-back + UR crank pulley + JWT S1 Cams
Cosmetics: SE-R wheels & skirts + Stillen Lip + CrystalClear Headlights & Corners + 98 Sentra Grill
Suspension: Tein Basic's + Front & Rear Strut Bar
OmegaManEX is offline   Reply With Quote
Old Mar 2nd, 2004, 11:34 AM   #8 (permalink)
sunnysentra
Nissan Addict
sunnysentra's Avatar
living in PA is nice because we have limits 130 ppm. If you are under 5,000 miles you are exempt from emissions testing. But, take off the EGR and clean it out with Carb cleaner and clean the pipe, make sure the vacume lines are good also, replace them if its bad. Make sure your ignition system is good also, plus you may have a leaky injector that is dumping fuel, you never know. I would run the engine on the Nissan Consult first to determine any sensor faults and that will tell you if you are running rich or not. If will tell you EGR settings also and red flag you voltage readings from that.
Chris 92 classic
Part of the AUTO / MANUAL SWAP CLUB
sunnysentra is offline   Reply With Quote
Old Mar 2nd, 2004, 11:41 AM   #9 (permalink)
James
in^3,N20,RPM,PSI
James's Avatar
Make sure all the vacum tubes that run the egr are working and not torn, specifically the one right under the egr that connects it to the BPT. I'm betting good money you'll find a hose leaking.
05 Frontier SE CC 4x4 (6spd)
97 Pickup EGR problem viper2 Truck & SUV 11 Aug 30th, 2003 06:27 AM
EGR, Smog problems rallysentra GA16DE 1.6L Engine 2 Jun 20th, 2003 11:05 AM
EGR problems dookie GA16DE 1.6L Engine 1 Apr 30th, 2003 06:44 AM
Newb with an EGR problem... ArCerian GA16DE 1.6L Engine 8 Oct 30th, 2002 09:16 PM
EGR control valve...... qinsac SR-Series Engines (DE/VE) 6 Oct 11th, 2002 09:54 PM
