ok my car wouldnt start two days ago when i went to start it so i checked the obvious signs and everything was cool ....then i could hear a click from the clutch relay sensor so i messed with it then waited a few and it started .....then the next day after starting up fine about 20 times that evening at the same time same place it would start so i did the same and it worked........but this evening after starting up all day fine at about the same time it wouldnt work so i tryed and tryed messing with it but no luck whats a good way to test and see whats wrong if it realy is the relay.......
yeah positive i pretty sure its the solenoid cause thats where the power is stopping its still getting about 12 v we tested it with a volt meter......im gonna replace the starter tomorrow
get the starter from the junkyard for about $40
95 200sx se. sr20de, gt28r, bb manifold, forge fmic, greddy bov and bc, tial 38mm, walbro 255, apexi tt, 3" exhaust with magnaflow, 3" downpipe, jgy clutch flywheel and fuel rail, msd 50#'s, cobra maf, jwt ecu and s4's, nismo fpr, autometer, nissport adaptors, fal pushers, ur pulley, m/t 22x8x15 et drags.
im not going to school tomorrow we are gonna change it.....my uncle the porche man is gonna help me swap it .... we did some problem shooting and switched some of the relays around that didnt work then we took the screw drivers and try to touch the positive side of the ignition switch to see if the solenoid was getting any power and it was but i guess something was wrong with it so it wasnt turning over....no clicking was coming from the ignition switch or solenoide so was pretty sure thats what it was so i pushed started it and got it home...
replaced starter today and everything is WORKING YEAHHHHHHH.......got a good starter with a lifetime warranty so i never have to pay for another one.....its a napa starter starts up like a charm
