» Site Navigation
» Other Sites
» Network Links
Feb 24th, 2004, 07:30 PM
#1 (permalink )
Yellow Submarine
all motor ga16de
i'm just sitting around in my dorm and just being bored and just thought if anyone ever wanted to create a decent all motor ga16 what mods would they get. after just searching around for a moment and just gathering parts here and there heres the list i came up with in no particular order. Just something for people to talk about. I'm not really interested in doing this, i would rather go the turbo route but for the unique people out there.
HS Header
HS CAI
AEM bypass valve
UR Pulley
Stromung Cat Back Exhaust
High Flow Cat
JWT Cams
JWT ECU
Big Bore Throttle Body
Port and Polished Head
JDM GA16DE with LSD transmission
Rebuilt Engine and Transmission
ACT Stage II Clutch
Fidanza Lightened Flywheel
11:1 Pistons
Lightweight Rods
Extrude Honed intake
.40 over bore on the block
NGK plugs and wires
ES motor mount inserts front and back
Front and back Strut Tower bars
Suspension Techniques front and rear sway bar
High Compression on the engine
Light weight wheels
Gutted Interior and Trunk
Short Shifter
AD22VF brakes
Steel braided brake lines
Carbon Fiber hood
Ground Control Coilovers and Camber Plates
KYB AGX Shocks and Struts
MSD 6A Ignition System
Racing Seats and 6-point harness
Roll Cage
Walboro 255lph fuel pump
1997 Nissan 200SX SE
18'' Quantum Tek S-10's
Extreme Front,M3 Sides,Drift Rear
Feb 24th, 2004, 07:36 PM
#2 (permalink )
in^3,N20,RPM,PSI
12.5:1? And run what gas???
Mike Saiki has most of all that stuff done.
Feb 24th, 2004, 08:06 PM
#3 (permalink )
Right By DA Beach....
you could also look at
www.sentra.net and see about the same as what this guy just posted
In the process...
Feb 24th, 2004, 11:43 PM
#4 (permalink )
Have I Hit 12's Yet?
that list covers alot, but unless you got alot of money to cover the custom work, i dont see it happenning
95 200sx se. sr20de, gt28r, bb manifold, forge fmic, greddy bov and bc, tial 38mm, walbro 255, apexi tt, 3" exhaust with magnaflow, 3" downpipe, jgy clutch flywheel and fuel rail, msd 50#'s, cobra maf, jwt ecu and s4's, nismo fpr, autometer, nissport adaptors, fal pushers, ur pulley, m/t 22x8x15 et drags.
Feb 25th, 2004, 09:33 AM
#5 (permalink )
I command you to SEARCH
You would not need the cage...
Sean M.
"Can you feel it building? Devastation is on the way!"
#6 (permalink )
yeah extra weight
In the process...
Feb 25th, 2004, 10:49 AM
#7 (permalink )
does anyone know the exACT ruling when it comes to having a rollcage? its based on time, is it not?
Feb 25th, 2004, 10:50 AM
#8 (permalink )
i kno certain tracks require rollcages if your running certain times .....i know for convertibles even if tops up if it runs like a 13 you have to have one
In the process...
Feb 25th, 2004, 10:58 AM
#9 (permalink )
13.9 = helmet
11.9 = cage
that's here in Seattle....
Sean M.
Feb 25th, 2004, 11:58 AM
#10 (permalink )
Yellow Submarine
what kinda of numbers would this ga16de pull
Feb 25th, 2004, 11:59 AM
#11 (permalink )
in^3,N20,RPM,PSI
assuming you can run the 12.5:1 pistons....
like 130... :P
Feb 25th, 2004, 01:11 PM
#12 (permalink )
Depends on the driver...
Sean M.
Feb 25th, 2004, 01:16 PM
#13 (permalink )
Former SuperMod
Originally Posted by 1CLNB14
13.9 = helmet
11.9 = cage
I believe it was that way in AZ as well.
<<Joe>>
The B13 is gone... now enjoying a Black 2005 VW GTI 1.8T
Feb 25th, 2004, 02:42 PM
#14 (permalink )
13.9 = helmet
11.9 = cage
same here in cali.
1994 4 door BBDET auto - manual swap club :D 16" enkei rims,3'' custom cat-back ,5zigen muffler, GC coilovers, KYB AGX adjustable shocks, drifter bodykit
clubNIMSO
Feb 25th, 2004, 05:31 PM
#15 (permalink )
that thing would move
Linear Mode
