Sentra GTS clutch, acceleration, power steering problems
hi! i'm marco from manila, philippines. i just bought a 1998 nissan sentra GTS, and i'm hoping to get any help for my problems with this car, which are as follows:
1. clutch pedal needs extra effort; doesn't have nice freeplay.
2. delayed acceleration (from 0 Kph) and has dragging effect.
3. steering wheel (or system) is noisy when turned to left or right.
it has a GA16DE engine/B14 chassis, had gone spark plug, oil, filter (oil and fuel) change and timing adjustment already, but its still yet to be fixed. any help? thanks!
1998 Nissan Sentra GTS
1998 Isuzu Hi-Lander S
spray some wd-40 on the cable of the clutch may loosen it up some and have it adjusted cable clutches have to be adjusted every now and then we dont have the luxury of a hydrolic one
hi nuskool!
thanks for the advice. btw, i found out that the clutch cable is worn already, so replacing it with a genuine one fixed that problem.
mcsolomon
Have you checked your fluids? May be a no brainer, but some people forget... Also, is the car a 5spd or auto tranny?
Cherry Bombs make great dual exhaust... Removing them make people cry.
Ram Air made with Hood scoop a work in progress.
If I was really interested in what kind of car you had, I'd look in my rear view mirror...
Check out My Sentra and my racing team
thanks for your advices. yeah, its a 5-speed M/T. as i've said, i got a new clutch cable and it fixed the freeplay problem. by advancing the timing also improved the acceleration, though i still have the steering woe, esp during turning at low speeds. i checked the power steering fluid, and its in normal level. what must be wrong with my steering system? thanks in advance!
mcsolomon
i don't know what noisy means but get that alignment done and give more details on what kind of noise it is and where it sounds like its coming from.
hello james!
it sounds like a bearing gradually crushed, and its vibration is felt through the steering wheel. some mechanic told me i need to replace my power steering hose, but that would cost me too much. do you have any idea what/how to tweak this thing? thanks!
mcsolomon
OT: read your PM. thanks for your recommendation.
Originally Posted by James
Dude he said he replaced the clutch cable... its a manual.
sorry, I was still in morning mode... If it reverses the events at all, I say I feel really stupid right now.
