Old Aug 28th, 2002, 12:04 PM   #1 (permalink)
calfaro
Send a message via AIM to calfaro Send a message via Yahoo to calfaro
Question Window /motor problem, know the part number?
My car is a Sentra GXE 92
power everything and AC 1.6L engine
My front passenger window does not work. I took it to a shop and they said the motor works (and showed me) but they also told me that the swith on the drivers door is defective and needs to be replaced. I called a nissan dealer and they were not too helpful. Anyone would know what is the part number so I can order it - the dealer told me that if I had a part number they would order it for me.
And second, its the climate control selecting motor. I have to get down below the dash to change from say defrost the windshield to bi-level operation. Not too bad but would like to know what is the part number of that motor so I can order it as well. Everything else works in the car (well almost)
Thanks to anyone who knows the answer (s) to this question (s) it will be greatly appreciarted, or please tell me where I should post this question
calfaro is offline   Reply With Quote
Old Aug 28th, 2002, 12:45 PM   #2 (permalink)
Michael DeLoach
Go to your local junkyard and pull these parts out of a car there.
Michael DeLoach is offline   Reply With Quote
Old Aug 28th, 2002, 01:33 PM   #3 (permalink)
calfaro
i tried
I tried and I was told that I had to buy the whole door/swith pannel/box and the whole middle console (with the ac controls) otherwise they won't sell - definately way too much - I want to know if anyone has the part number cuz then I can get it new from Nissan and I was told it would not be too expensive - by the mechanic who looked at my car.
Thanks
Old Aug 28th, 2002, 08:13 PM   #4 (permalink)
azkicker0027
Cone Dodger
azkicker0027's Avatar
Send a message via AIM to azkicker0027
the dealership can't get the part number?? what a surprise, really, what a surprise.......and if the motor works for the window, don't rule out the window regulator/lifting mechanism......
Naturally aspirated autocross car.............naturally.
http://members.cardomain.com/azkicker0027 And defending STF in the process.
http://www.200sxonline.com/community/
azkicker0027 is offline   Reply With Quote
Old Aug 28th, 2002, 10:13 PM   #5 (permalink)
calfaro
not that they can't get it..
They were not too cooperative. It seemed that if you dont have a new car, they wont stop to ask you if they can help.
It was frustrating. I ordered one part in the past and went to pick it up. After calling and making sure they had the part it took me more than 25 minutes for someone to get the part - with me the only person in line and 3 people in the parts/stock room.
I am not out to bash Nissan - just what happened to me then
Actually, I have seen the window go up and down - this tech from a window shop took the battery of his 12 volt drill and plug it to the motor behind the door pannel and the window went up and down and that is why he told me that it could be the relay - but on the driver's door...
Any other ideas? I am frustrated trying to get the part numbers..
Old Aug 28th, 2002, 10:24 PM   #6 (permalink)
azkicker0027
Cone Dodger
well if he bypassed the window controls and just directly fed the motor, it could also possibly be harness related, power or also ground.....i don't know.....
Old Aug 29th, 2002, 08:31 AM   #7 (permalink)
Ninety-Nine SE-L
Please Shift Here
Ninety-Nine SE-L's Avatar
Send a message via AIM to Ninety-Nine SE-L
This could be a long shot, or just plain stupid, but the driver's side window switch has a child lock on it. It's right next to the power lock switch. Maybe you pressed the button accidentily. The button disallows any switches to open the pasanger side (and rear..sentra) windows and the driver's window will still be operative.
Ninety-Nine SE-L is offline   Reply With Quote
Old Aug 29th, 2002, 10:36 AM   #8 (permalink)
calfaro
it would have been too easy
Thanks - I was hoping so I walked out in the rain to see if that was the case.
My rear passenger door has a child lock button but nothing else. The (front - which has the problem) passenger door doesn't even have a child lock button.
I will keep my ears open to see if anyone can come up with the part number - which may be the relay located on the drivers door.
Thanks again
Old Aug 29th, 2002, 11:14 AM   #9 (permalink)
toolapcfan
Your electrical friend
toolapcfan's Avatar
So what do you need part numbers for, the drivers switch or the HVAC control doohicky or both? They just didn't want to get out the mircofiche (sp?) and look up the numbers, lazy fucks. I'll tell you what, there are few people worse than a $tealership parts department guy. They're like DMV people, no matter where you go, they suck. I take that back, a guy that used to help me at a MAzda $tealership was pretty helpful. The guy at my Nissan dealer looks like he's about to pass out or slit his wrists. I don't mind making him do his job. I like a challenge, you let me know what parts and I'll get you part numbers. Give me your Vin though, cuz this guy is going to ask me for it, he'll say, "Anything trim or interior, gotta have a VIN" You could always e-mail that guy down at mossy or courtesy nissan, those guys help us out pretty good from what I've heard. I'd give you the URL's but when I did a search for them over at the SR20DEforum, when I click on thread it doesn't pop up. Big surprise there. Anyway, Let me know. That drivers window switch control is all one assembly though isn't it? I don't expect it to be cheap, I'm guessing at least $60.
Rob '93 SE-R
PM or e-mail me for Progress swaybars $190 shipped, B13 Progress coilovers $1300 shipped and B13 Progress LCA brace $160 shipped.
toolapcfan is offline   Reply With Quote
Old Aug 29th, 2002, 11:47 AM   #10 (permalink)
calfaro
here it is
The relay or switch wich sits on the drivers door and which controls the passengers side power window.
Also the Motor which is activated when you choose which vents the air will come from. I can't get out right now from work cuz its raining here in NY and I need to get down to get to see if they have any visible numbers.
My car is out in the open so I have to wait to see when I can get under the dash.
Thanks.
Old Aug 29th, 2002, 01:31 PM   #11 (permalink)
toolapcfan
toolapcfan's Avatar
I'd just call or e-mail Mossy @ www.mossyperformance.com e-mail gregv@mossy.com or Courtesy @ www.courtesyparts.com e-mail sales@courtesyparts.com
Rob '93 SE-R
Old Apr 9th, 2003, 10:05 PM   #12 (permalink)
mk_sentra
how many relays totally
hi
i have a similar 92 sentra 1.6 all auto power gxe.
three months back, sometimes the power windows and locks would go out for a day once in a week.
now for the past 3 weeks, its gone completely.
previously i used to hear relays activating when i used the power in the door and windows. so i want to know how many relays are there totally for the power operation.
thanks
mk
mk_sentra is offline   Reply With Quote
Old Apr 10th, 2003, 07:28 AM   #13 (permalink)
calfaro
Question I am not sure
My problem was not solved, I kind of kept it in the back burner.
I have noticed the following on my car: teh seat belt light was on for 3 days and then it went away. Also, the cruise control stop working for 2 days and then it started working again.
A friend who had an older sentra said that they do suffer from electrical problems after a while - for him they were so much that he changed his car. He told me, its a chain reaction, one the first thing happens, the whole car tends to have problems. I am starting to see that but I will wait a little longer before I change my car.
In you case what I can recomment is buy the small diagnostics tool (sometimes in the autopart places for $20.) and run a diagnostics to make sure its nothing serious, if not take it to a mechanic u trust to see what they can tell you.
The chilton's manual tells you how many and where the relays are but I do not own the book - I had it for my previous car and they are very complete.
Old Apr 10th, 2003, 09:09 AM   #14 (permalink)
toolapcfan
toolapcfan's Avatar
Chances are they used modules that have built in relays, but it typically takes two relays per window and two relays total for the power lock system, so 10 relays total for the power windows and locks on a 4 door car. You could have a bad switch or bad connection MK. Everything starts at the driver's control switch, so if things aren't working, that's the place to start.
Rob '93 SE-R
Old Apr 10th, 2003, 09:22 AM   #15 (permalink)
Daishi
Send a message via ICQ to Daishi
Same problem
I also have a '92 GXE and I have had the same problem, except that my window will roll up, but that is all it will do. If I push the button up or down it just goes up. I also have the same issue with the HVAC and related controls. From what I've experienced the motors are okay in my case, but they just don't like to switch right away, which may be a problem with the HVAC itself.
Daishi is offline   Reply With Quote
weird electrical problem??? IXLR8se-r B14 95-99 chassis 9 Jun 1st, 2005 08:28 AM
Tiny (?) electrical problem - 92 SE-R RED92SE-R B13 91-94 chassis 10 May 17th, 2004 12:38 PM
A/C electrical problem tsi200sx B13 91-94 chassis 8 May 1st, 2003 02:16 AM
Request for help: diagnose electrical problem boost Truck & SUV 7 Apr 29th, 2003 01:56 PM
another electrical problem Laly B13 91-94 chassis 9 Jul 10th, 2002 02:27 PM
