Old Aug 27th, 2002, 02:30 PM   #1 (permalink)
Brainstorm
Fuel Pump
Here's my issue with the fuel pump. When the needle on the fuel gauge shows slightly below a quarter, everytime I make turns (left or right - well more on right turns) the pump cuts out (just like the ignition cut off by the speed limiter.) Initially I thought maybe the needle is just wrong and I do actualy need to refuel. so I did, but I only squeezed in a mere 40L (and I do mean squeezed.) So the next time the needle went below the quarter mark, I just continued to drive till when I thought it would be empty (basicaly I drove until the ignition would cut off at the slightest turns.) At that time I filled up just shy of 50L (which is the tank capacity.)
The problem is that I don't want to fill up at 1/4 full and I don't want to put up with the ignition cutt off and all the jerking associated with it. Is there somethig I can do? Upgrade the pump maybe? Is this happening for others as well?
BTW I have 95 200SX SE
95 200SX SE
Eibach Sportlines with KYB AGX's
Custom interior - modified seats w/ white vinyl, custom embroidery
Brainstorm is offline   Reply With Quote
Old Aug 28th, 2002, 08:10 PM   #2 (permalink)
azkicker0027
Cone Dodger
azkicker0027's Avatar
Send a message via AIM to azkicker0027
how fast of a turn do you make to starve the fuel pump, also, when was the last time you changed the fuel filter, and if it happens when turning, i think there's too much sloshing around the tank, aren't there supposed to be baffles to prevent this?? somebody back me up here.........help this guy out........
Naturally aspirated autocross car.............naturally.
http://members.cardomain.com/azkicker0027 And defending STF in the process.
http://www.200sxonline.com/community/
azkicker0027 is offline   Reply With Quote
fuel pump srv54 New Member Forum 1 Dec 4th, 2003 09:57 AM
fuel pump question PlatinumGold '96 B14 95-99 chassis 5 Nov 9th, 2003 11:08 PM
ghost fuel pump project4 General Discussion 6 Nov 9th, 2003 11:09 AM
fuel pump 240sxbegginer S13 240SX 1989-1994 2 Sep 9th, 2003 09:06 PM
B12 fuel pump.... phaedrus432 E/CA-Series & GA16i Engines 4 Jun 8th, 2003 12:31 AM
