Old Jan 1st, 2004, 01:48 AM   #1 (permalink)
psteng19
Can I reset the CEL (without the OBD scan tool) by unplugging the battery?
CEL came on, most likely because of rear O2 sensor.
I had a leak in my downpipe (I think it's called the downpipe) so the O2 sensor probably wasn't reading the normal levels.
I didn't actually scan the codes.
I replaced the pipe which fixed the leak but the CEL is still on. Should I just unplug the battery overnight?
Assuming the exhaust leakage was the cause, will that shut off the CEL?
The reason I ask without trying is because I don't feel like resetting all my radio stations for no reason if it doesn't work
psteng19 is offline   Reply With Quote
Old Jan 1st, 2004, 02:27 PM   #2 (permalink)
Scott
Post Freak
Yes, unplugging the battery overnight should turn off the light. If the problem is corrected you should be fine, but if not the light will probably turn on again soon.
Scott is offline   Reply With Quote
Old Jan 6th, 2004, 12:17 AM   #3 (permalink)
TOOQIK
SLAVE TO THE GRIND
TOOQIK's Avatar
Send a message via AIM to TOOQIK Send a message via Yahoo to TOOQIK
or just reset the ecu by turning the screw in the back takes less then five minutes to undo it reset it and put it back in......
NEED TURBO PARTS...GOAL....500WHP!! PLEASE HELP NEEDY SPEED FREAK WILL ACCEPT ALL DONATIONS :thumbup:
TOOQIK is offline   Reply With Quote
Old Jan 6th, 2004, 12:45 AM   #4 (permalink)
Token Moron
My ass, your face
Token Moron's Avatar
Send a message via AIM to Token Moron Send a message via MSN to Token Moron
plus, u can also pull the code of whats really causing the CEL while doing that.
91 se-r : sr20det= the beast
96 sentra : ga16de= pimpness
00 frontier : ka24de= tow truck
01 sentra : gq18de= stock mofo
Token Moron is offline   Reply With Quote
Old Jan 6th, 2004, 02:35 AM   #5 (permalink)
dry
NF's Offical Post Whore
dry's Avatar
Send a message via ICQ to dry Send a message via AIM to dry Send a message via MSN to dry Send a message via Yahoo to dry
funny thing happened to me, my battery died... I swapped... and the CEL still comes on without starting up the car... I dunno, I thought that cutting off the power to it would reset it, maybe my car is some kind of GA16 ECU god. :shrug:
dry is offline   Reply With Quote
Old Jan 6th, 2004, 05:30 AM   #6 (permalink)
vashna
Send a message via ICQ to vashna
What's CEL mean ???? (check engine light ) ??? and how do you "pull the codes" from your ecu and figure out what they mean ????
vashna is offline   Reply With Quote
Old Jan 6th, 2004, 10:36 AM   #7 (permalink)
Token Moron
My ass, your face
CEL=check engine light......u reset the ecu by turning the screw in the back of the unit all the way and hold it for 2 seconds, then turn it all the way back, the CEL will then start flashing in a series of long flashes first, then short flashes next, u have to remember how many times it flashes slowly and how many times it flashes fast, if u have a chiltons manual, it tells u the codes and what they mean, if u dont have one, check out www.sentra.net
Old Jan 6th, 2004, 07:54 PM   #8 (permalink)
tkvtec
Speed Addict
tkvtec's Avatar
Send a message via AIM to tkvtec Send a message via Yahoo to tkvtec
I know this sounds kinda funny, but It worked on a couple Altimas I did it to.
I forget exactly, but you either turn the ignition key to accessory or to on (try both). As soon as you do, press the door switch that triggers the dome light as many times as you can in 10 seconds. Turn off the ignition and turn it back on again. Before attempting I would set the Dome light to the off position. May or may not work. I'll go try it now to see if it makes mine go away. I'll get back to you.
Didn't work for me, but it didn't work the first time I did it to one of the Altimas I did. It took a couple tries.
JWT ECU | Hotshot CAI | UR Pulley | Motivational Struts | Kosei K1 16's | Yokohama Parada Spec II 205/45 | JWT Flywheel | ACT Street | HS Header | Pacesetter STS | AD22VF | 2" Cat-Back
My Car...Click Here
tkvtec is offline   Reply With Quote
Old Jan 8th, 2004, 02:55 AM   #9 (permalink)
sno
**best avatar award**
sno's Avatar
that's gotta be about the funniest thing i've heard all day! LOL! what in the world would make you think that would work?!? LOL!
sno is offline   Reply With Quote
Old Jan 8th, 2004, 05:54 AM   #10 (permalink)
tkvtec
Speed Addict
tkvtec's Avatar
I found it on altimas.net about a year and a half ago.
It actually did work on more than just a couple cars I did it to.
I was hoping that since this is a Nissan too that it would work on it too, but maybe not. It worked on a couple first gen altimas I did it to, and one of my friends with a different kind of car altogether had a CEL and I told him about the little trick I did and it worked for his too. I think it was a Honda or something, I don't really remember.
My Car...Click Here
OBD I scan tool for a 1992?? lotus197 B13 91-94 chassis 1 Sep 8th, 2003 10:19 AM
Can dealer tell if ECU was reset by disconnecting battery? dschrier QG18 1.8L Engine 4 Aug 21st, 2003 12:19 AM
Can I buy the tool to reset the Air Bag Light? HardlineFan B14 95-99 chassis 0 Aug 2nd, 2003 09:36 AM
CEL on, will it pass smog if it's reset?? nismoprincess GA16DE 1.6L Engine 14 Mar 4th, 2003 07:59 PM
Recommended battery DNYC B11/B12/KN13 82-90 chassis 21 Feb 4th, 2003 09:37 PM
