Old Aug 14th, 2002, 12:46 AM   #1 (permalink)
nissanracer805
Posts: n/a
Unhappy fuel pump problems?
Whats up guys, i'm stuck.....i have a 96 sentra gxe (auto)...about a month ago, i woke up one morning, went outside, got in the car.....and tried to turn it on, but the car wouldnt start, it would turn, but wouldnt start...i let it chill for a while, and it started.....it did that for a couple days, sometimes it would be fine, thinking it might be a faulty fuel filter, i replaced it, checked the fuel pump, works fine..........it weird because once the car starts, it wont stop, sometimes it starts and after 5 seconds, the car shuts off....battery is new.....haunted?
Old Aug 15th, 2002, 04:27 PM   #2 (permalink)
justinr983
Posts: n/a
i had the same problem with my 91 nissan sentra. You might check the last foot or so of fuel pump wiring near your gas tank
Old Aug 15th, 2002, 06:18 PM   #3 (permalink)
nissanracer805
Posts: n/a
i know this guy at work who's brother is a mechanic and he thinks the problem is the fuel pump, he says that they have some kind of circuits inside and they arent receiving enough voltage from the battery because they are possibly dying....i dont know..
Old Aug 15th, 2002, 06:46 PM   #4 (permalink)
javierb14
3 bar MAP
javierb14's Avatar
Send a message via AIM to javierb14
hmmm..i dont know how a bad fuel pump would let ur car continue to run. does it still run after u turn the ignition off? is it "dieseling"? it kinda sounds like an ignition gremlin.
www.full-race.com
Anything else is half fast!
866.FullRace
javierb14 is offline   Reply With Quote
Old Aug 15th, 2002, 10:27 PM   #5 (permalink)
nissanracer805
Posts: n/a
nope, the engine doesnt diesel, it shuts down normally, it hasnt had this problem in a while now (knock on wood) but it does happen occasionally, it might be a faulty connection, but then again, i dont know, thats why i'm asking the experts
Old Aug 15th, 2002, 10:35 PM   #6 (permalink)
javierb14
3 bar MAP
javierb14's Avatar
check/test the park neutral switch.....put it in park/neutral and see if it starts. put it in gear and see if it starts. move it around....and c if it has any effects.
do u have an alarm?
www.full-race.com
866.FullRace
Old Aug 15th, 2002, 11:05 PM   #7 (permalink)
nissanracer805
Posts: n/a
doesnt have any effects, i do have an alarm. not a factory one tho. but the alarm works fine and i've had the alarm since the third day i had the car so i know it cant be the alarm.....maybe
fuel pump srv54 New Member Forum 1 Dec 4th, 2003 09:57 AM
fuel pump question PlatinumGold '96 B14 95-99 chassis 5 Nov 9th, 2003 11:08 PM
fuel pump 240sxbegginer S13 240SX 1989-1994 2 Sep 9th, 2003 09:06 PM
B12 fuel pump.... phaedrus432 E/CA-Series & GA16i Engines 4 Jun 8th, 2003 12:31 AM
Anyone ever use a Supra TT fuel pump? ktrends B13 91-94 chassis 0 May 15th, 2002 11:00 PM
