Old Aug 13th, 2002, 11:14 AM   #1 (permalink)
ursbasu
Posts: n/a
Question Starting problem when wet
I have 92 Nissan Sentra 1.6L. It runs great and been a great utility to me.
The problem I face with my car is when it gets wet either during a car wash or heavy rain. When wet after a wash, it is hard to crank start and takes a couple of days before it cranks back again. When wet during rain, it takes about a 4-5 hours to crank back again.
Unless completely dry although it starts the idling is jerky.
Distributor cap and spark plugs have been replaced recently. It has not helped fix the problem even after replacing the distributor rotor, cap and sparkplugs. Does any one have a clue as to what could possibly wrong.
Old Aug 13th, 2002, 01:16 PM   #2 (permalink)
By Nature
Nissan Fanatic
Send a message via AIM to By Nature
was the problem there before you did tune up? or did it appear after? did you replace distributor rotor?
I would say re-check plugs and wires and put some electric grease inside the wire sleeves where they touch spark plugs
"Those who stand for nothing, will fall for anything"
2003 VW Jetta 1.8
1998 Nissan Sentra 1.6
By Nature is offline   Reply With Quote
Old Aug 14th, 2002, 04:29 PM   #3 (permalink)
niky
Doodeee doodee doodee doo
niky's Avatar
if it's none of the above, you can also check your oil cover. Maybe moisture is getting into your air intake? Are you running a custom intake or the stock?
Bigbigcar.com
My new hobby... driving.
Ford Lynx RS / Mazda Protege MP3: Slow but Furious out of the box. :D
niky is offline   Reply With Quote
Old Aug 15th, 2002, 08:44 AM   #4 (permalink)
Russellc
Not sure if this will help, but once when I was doing an under the hood detailing, I accidentally got water on top of the engine where the fuel injecters are. The car would not start! I left the hood up a couple of hours and it started, ran rough a few seconds and then the problem never returned. Hopethis is of some help.
Russellc is offline   Reply With Quote
Old Aug 26th, 2002, 02:34 PM   #5 (permalink)
ursbasu
Posts: n/a
Thanks
Thanks for all your feedback. Right now I am trying to avoid the car getting wet but in future if I encounter this problem I will check the fuel injector as well as the oil cover. I might do that very soon let you all know the results. But if any one else has encountered this problems and has been able to fix it, please do let me know.
Thanks to all
Old Aug 27th, 2002, 04:24 AM   #6 (permalink)
GundamONE
haha strange...when wet...something must be getting through to the engine. i'm surprised the old ones have this problem because newer cars have all these electrical wires EVERYWHERE
"I live my life 1/4 mile at a time...for those 20 seconds...i'm free." -SentraRacer97
GundamONE is offline   Reply With Quote
Old Aug 27th, 2002, 05:40 AM   #7 (permalink)
niky
niky's Avatar
<snip> i have 2 2000 model sentras and they both start buzzing like hornets when i'm driving at night or in the rain.
Bigbigcar.com
Old Jul 31st, 2004, 09:21 PM   #8 (permalink)
PGD_NX
i have the same problem right now with my nx 1600 it happens only when it rains alot and i have to let dry out to start it again if you figured it out please tell me because im sure its the same problem, and i know its not my spark plugs/wires or disturb cap its something else. my fuel pump runs the engine turns but theres nothing.
thanks alot
PGD_NX is offline   Reply With Quote
Old Aug 1st, 2004, 10:01 PM   #9 (permalink)
astreamk1
B12 Enthusiast
astreamk1's Avatar
Is your coil getting wet ? Sounds like it may be grounding out . I had a toyota pickup that suffered the same problem. I used to carry a small can of WD40 with me and if it got wet, I would spray the coil down with it, once the WD40 would displace the water I'd be on my way again. They do make cans of silicone wire dry too you can spray your wires and coil with.
My Car Domain Page.
astreamk1 is offline   Reply With Quote
Old Aug 2nd, 2004, 12:59 PM   #10 (permalink)
BikerFry
Come here often?
BikerFry's Avatar
Replace your Plug Wires.
If you wanna be sure before you replace them, mist them with a spray bottle of water while the car is running and listen for pops and look for sparks. You might get bit but it won't do any permanent damage.
Is this forum still full of n00bs learning that you can't boost your daily driver on a part time retail income?
BikerFry is offline   Reply With Quote
Old Aug 2nd, 2004, 02:08 PM   #11 (permalink)
stevja1
Slashie
stevja1's Avatar
Send a message via MSN to stevja1 Send a message via Yahoo to stevja1
Would a leaky vacuum line do this? I heard also that if you spray water in your engine bay while the engine is running, and (without sparks and stuff), it starts to stall, you probably have a vacuum leak. I don't know if that would happen when it is raining or not. I do know that with vacuum leaks, your engine idles ruff, and it may be hard to start, but you'll get a CEL.
'00 Sentra SE /w pp: Injen Intake : ES MMIs
Visit my website!
stevja1 is offline   Reply With Quote
Old Aug 3rd, 2004, 01:23 PM   #12 (permalink)
BikerFry
Come here often?
BikerFry's Avatar
Yeah a leaking vaccuum line could do it. Plugged EGR too. I don't know about spraying water revealing a vaccuum line problem. I'm not saying it won't, I just have no knowledge on this myself. You could probably hear it whistling too. Start feeling around by the EGR for cracks or holes in any of those rubber lines. Make sure your EGR's not stuck too. With the car running, gently lift from the underside on the diaphragm and make sure it moves and bogs the engine when you lift it.
Old Aug 3rd, 2004, 01:24 PM   #13 (permalink)
James
in^3,N20,RPM,PSI
James's Avatar
without 'sparks' your engine wouldn't be running.
a vacum leak should still let the engine start.
05 Frontier SE CC 4x4 (6spd)
Old Aug 4th, 2004, 10:23 PM   #14 (permalink)
STRATTON
I WANT BOOST !!!
STRATTON's Avatar
Send a message via AIM to STRATTON
a huh
i had this same exact problem with my 1992 oldsmobile regency 98 elite, when the engine would get wet it would run like shit so me and my pops took a spray bottle sprayed over near the ignition coil and saw sparks arching off that onto my altanator so i replaced two ignitioin coils and the problem hasnt happend since, u should try the good old spray bottle trick, ohh yeah i forgot to add that i stepped on the break and pressed the gas also to get the sparks going u can actually see them arching like crazy well in my case...hope this helps...
COMPRESSED CLIQ
STRATTON is offline   Reply With Quote
Starting problem!?? 93altima U13 1993-1997 Altima 2 May 7th, 2003 07:51 PM
problem when starting 97sentragxe B14 95-99 chassis 4 Apr 20th, 2003 01:20 PM
A32 starting problem 93blackbird General Maxima Discussion 0 Mar 6th, 2003 02:11 PM
My Theory on the infamous B12 Starting problem... LittlebittaContact B11/B12/KN13 82-90 chassis 6 Jan 8th, 2003 08:34 AM
Problem with starting andre GA16DE 1.6L Engine 4 Dec 22nd, 2002 08:46 PM
