Rattling Noise - Nissan Forum
post #1 of 23 Old Aug 8th, 2002, 04:07 PM Thread Starter
DNE's VZR Conversion
LIUSPEED's Avatar
Send a message via AIM to LIUSPEED Send a message via MSN to LIUSPEED Send a message via Yahoo to LIUSPEED Send a message via Skype™ to LIUSPEED
Question Rattling Noise
I dont know if you all had this problem before but sometimes when i am driving with my A/C on i hear a small rattling sound every time i push the gas pedal down. I hear it coming from the engine bay area. it loud enough for me 2 hear. This happened a while ago and i ignored it but now it keep happening and is really annoying. It especially happens when it in hot weather.
n-e-advice 2 fix or you guyz still dunno what im talkin about.
95 Sentra GXE with Mods - SOLD
95 200Sx SE-R - work in progress
LIUSPEEDTUNING.COM always remember 12/31/08 RIP
LIUSPEED is offline
post #2 of 23 Old Aug 8th, 2002, 06:37 PM
3 bar MAP
javierb14's Avatar
Send a message via AIM to javierb14
detonation?
Anything else is half fast!
866.FullRace
javierb14 is offline
post #3 of 23 Old Aug 8th, 2002, 09:26 PM
Cone Dodger
azkicker0027's Avatar
Send a message via AIM to azkicker0027
most likely.......
it could be coming from your tensioner or idler pulleys, they tend to make noise, especially in warmer weather, and when you have the a/c on, it poses a load to the pulley, i have the same thing too, just too busy to do it, heck i even need to change tranny oil and drivebelts........
Naturally aspirated autocross car.............naturally.
Retired STF champ car.
azkicker0027 is offline
post #4 of 23 Old Aug 8th, 2002, 10:08 PM
Ive got a pickle 4 an arm
ScarCrow28's Avatar
i don't know but i can say i get a creaking noise in my right rear suspenson. like you it mostly happens in hot weather. and the hotter it is the more noise it makes its just a snap-creak that happens everytime the suspension moves. but the catch is that the shock doesn't seem to be blown, the car doesn't jump up and down. it just makes that annoying noise. doesn't happen in temps below 80.
Real Drivers SIT UP STRIAGHT.
The 2.5L Inline 4. Just four cylinders short of a 5.0L V8! Ijust need to figure out how to weld two of em together... :~
ScarCrow28 is offline
post #5 of 23 Old Aug 8th, 2002, 10:53 PM Thread Starter
LIUSPEED's Avatar
so do we need to tighten the tensioner or how about do we fix it?
LIUSPEED is offline
post #6 of 23 Old Aug 9th, 2002, 08:47 AM
Define_Sentra
Guest
Posts: n/a
Hey man i got the same ass problem!!!, i tried to post it once but no one knew what i was talking about, anyways mines makes noise when i drive it for a real long time and when i turn my ac on, going up hill, and when i tweek my auto pedal like one time when i was going 3500 rpm with the exhaust hella loud and i gently push the pedal and the rpm goes back down to 2000 when it does that i barely could hear my exhaust and the noise is even much louder... Hmm wierd i also heard it on other old cars
post #7 of 23 Old Aug 9th, 2002, 09:31 AM
Please Shift Here
Ninety-Nine SE-L's Avatar
I got that too. when I punch it, I can hear some rattling coming from the intake (I guess). It sounds like a nasty grinding/rattling noise. I have my timing up, it couldn't be pinging, could it? It doesn't sound like pinging.
Ninety-Nine SE-L is offline
post #8 of 23 Old Aug 9th, 2002, 10:03 AM
Nissan Fanatic
yo ScarCrow28
yo ScarCrow28 I know what the problem is because I had the problem myself, the rattling your hearing in your suspension is the spring moving around in the shock and not staying in the perch up top. Check it I was getting that same noisz from just the rears.....I had Eibach Sportlines and at the time brand new Tokico shocks. If you go to PDM-Racing.com (which had an extensive Nissan history as well) they have this product from Whiteline called coil wrap. You wrap all the "dead" or middle coils even while your springs are still on no disassembly is required and whala! NO MORE NOISZ! cool huh? the package to do two springs is $10.00 and there based in canada. Of course you could just go to an auto parts store and get some rubber tubing. Oh well the point is Noisz all gone!.....hope this was helpful....
Sentra GTR-1 is offline
post #9 of 23 Old Aug 9th, 2002, 01:34 PM Thread Starter
LIUSPEED's Avatar
i have exactly da same problem as define sentra..
i head maybe 89 octane gas might help
LIUSPEED is offline
post #10 of 23 Old Aug 9th, 2002, 01:54 PM
Banned
Niss200SXGTR's Avatar
Send a message via AIM to Niss200SXGTR Send a message via Yahoo to Niss200SXGTR
Im almost positive it could be your a/c condenser fan hitting something, check it to make sure there isnt any bends or anything.
Niss200SXGTR is offline
post #11 of 23 Old Aug 9th, 2002, 06:59 PM
Define_Sentra
Guest
Posts: n/a
no even tho i dont put my ac on
post #12 of 23 Old Aug 9th, 2002, 09:23 PM
3 bar MAP
javierb14's Avatar
do u have lowered suspension? a few different types of kyb agx's make noise and so do lowering springs. sometimes u cant get rid of it, sometimes u can. just turn up the radio
866.FullRace
post #13 of 23 Old Aug 9th, 2002, 10:25 PM
ScarCrow28's Avatar
Re: yo ScarCrow28
so i'm guessing you basically put a spring rubber in inthere. you know, like in NASCAR. cept for only ten bucks i doubt they do anything for handling. i'll difinetely check it out. i was thinking it may be comming close to time for a new shock or something its's a completely stock suspension. i don't think it has ever been changed.
now there is an idea. spring rubbers!?!?
post #14 of 23 Old Aug 9th, 2002, 10:32 PM
ScarCrow28's Avatar
that rattling noise could be the heat shields. all but the heat shield on my header has already rusted, rattled, and fallen off. when the ac is turned on the engine revs a bit higher for more power, annother belt starts turning and causes more vibration makeing the shield rattle against the exhaust. it goes away as you press on the gas and the engine smooths out. if you havn't replaced the exhaust system yet, they may be the problem. i noticed the hollow rattle after a one week recheck on my timing. when i hit the gas just right, or turned the ac on i got a rattle. i dont' have a tach so i don't know what rpm i was doing, but it wasn't much
post #15 of 23 Old Aug 10th, 2002, 03:14 AM Thread Starter
LIUSPEED's Avatar
my car ride height is stock.
heat shield .. iono.. dunt think so
it happens when i drive in hot temperature.
my timing hasnt been advanced. nothing has been done except my MAF adapter and filter..
and my exhaust.
LIUSPEED is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
lifter noise widman Truck & SUV 16 Oct 16th, 2008 08:22 AM
Need help with tire noise on NX jb-nx2k New Member Forum 5 Mar 5th, 2006 08:03 AM
For those of you that still have noise problems. LethalAudio Audio 1 Nov 12th, 2003 05:58 AM
rattling noise polishhotdawg B11/B12/KN13 82-90 chassis 8 Mar 28th, 2003 03:34 PM
Whats that rattling noise pearsont74 GA16DE 1.6L Engine 5 Feb 23rd, 2003 12:14 AM
You may post new threads
You may post replies
BB code is On
