Old Oct 1st, 2003, 09:21 PM   #1 (permalink)
tonsters200
Question Yankin out the engine...
Ok got a 96 1.6. What is the quickest way to yank out the engine? BTW It has a manual tranny.
tonsters200 is offline   Reply With Quote
Old Oct 1st, 2003, 10:49 PM   #2 (permalink)
rkeith
My car doesn't like you
rkeith's Avatar
tie the engine to a really large tree and floor the car in reverse
j/k.... there really is no quick was to take out the engine... you definately want to take your time and do it carefully. haphazard is never the way to do something. if youre looking to do it yourself buy a haynes, chilton or FSM of your car and read through that. Those will be a big help.
Tho I still like my tree idea....
Yeah, its got some mods...
rkeith is offline   Reply With Quote
Old Oct 5th, 2003, 09:52 PM   #3 (permalink)
kbrassfi
Nissan Fanatic
kbrassfi's Avatar
Send a message via AIM to kbrassfi Send a message via MSN to kbrassfi Send a message via Yahoo to kbrassfi
it is not an easy task by any means, I have done it, and can say that you need to be patient, the good thing about the electrical connections on our engine is that they will only work in one place, so it makes it easy putting it back in as well, I dropped the tranny out first, then took the engine out myself, and then put them back in together, other than that it is just going through and removing all the bolts that are keeping it in, and keeping them seperate so you know where they go, it can be done by yourself, but let me tell you from first hand experience it will go faster and be a lot less strenuous if you enlist the help of some buddies. Other than that have fun, make sure that you hook everything up the way it was before, tighten all your hoses, check your fluids, and make sure everything is torqued correctly
My 96' 200sx
kbrassfi is offline   Reply With Quote
