What changes would I have to make to a '97 Sentra GLE to accomidate an SR20DE (it has a GA16DE right now)? Do I have to put in new mountings?
Also, where could I get an SR20DE w/ trans. for cheap (besides ebay)?
Cherry Bombs make great dual exhaust... Removing them make people cry.
Ram Air made with Hood scoop a work in progress.
If I was really interested in what kind of car you had, I'd look in my rear view mirror...
Check out My Sentra and my racing team
Wow, sorry, I didn't realize until I read your thread...
Either get all the parts to bolt it in, or just get some angle iron,duct tape, twist ties,electrical tape,tinners snips, a plasma cutter and a mig welder to make it work
1998 Nissan Frontier XE/2wd/5spd 1 owner, 264k miles
1985 Olds Cutlass, 350 Chevy, owned for 14 years
WANTED: 1968-1973 Datsun 510 or 1991-1994 Sentra SE-R http://www.myspace.com/junkyardengineer
wow, too much work and I'm too lazy...
oh well, maybe sometime in the future
well its not really that much... just a matter of axles, a new rear mount IIRC and sr20 bits, pieces, electronics... if you found the front clip of an SE-R you should be okay....
you will most likely spend more money to buy the sr20de motor, the ecu, harness, mounts, ignitor switch and axels then you will if you just turbo the ga16de... a lot of people believe a swap is always the best thing when in reality, just work with what you got and it will be faster then just doin a swap.. especially sinces its a sr20de not a sr20det swap.. for a few grand you will gain like 30hp with just the sr20de swap.. you can turbo a car for less and gain a lot more
Originally Posted by hendrix
I can't wait until Hurrican Jamal sweeps up the east coast and steals the wheels and stero out of your car
