Old Sep 29th, 2003, 08:47 AM   #1 (permalink)
shughes
Send a message via Yahoo to shughes
puzzling oil leak (around crankshaft)
I have been trying to fix an oil leak on the passenger side. A couple months ago I resealed the oil pan which did not fix the leak. It looked like it might have been coming from the crankshaft oil seal area. I replaced the cranshaft seal this weekend and it indeed looked like that area had a possible leak. The area above the crankshaft right below the water pump also had some oil around it but I assumed oil was being kicked up from the crankshaft pulley. This morning my wife said there was a small pool of oil under the car in the same area so I am thinking I have not fixed my oil problem.
Are there any other areas I should be taking a look at? My Haynes manual said for my 1994 model that there is no camshaft seal to replace or the jackshaft seal.
shughes is offline   Reply With Quote
Old Sep 29th, 2003, 10:28 PM   #2 (permalink)
azkicker0027
Cone Dodger
azkicker0027's Avatar
Send a message via AIM to azkicker0027
jackshaft seal?? what the??
Naturally aspirated autocross car.............naturally.
http://members.cardomain.com/azkicker0027 And defending STF in the process.
http://www.200sxonline.com/community/
azkicker0027 is offline   Reply With Quote
Old Sep 29th, 2003, 10:41 PM   #3 (permalink)
JWolfe
Check the oil pressure switch. They can and do fail.
JWolfe is offline   Reply With Quote
Old Sep 29th, 2003, 10:55 PM   #4 (permalink)
Dwntyme
High times
Dwntyme's Avatar
It's the Harmonic ballancer seal(front seal) suprized your rear seal
is not leaking yet,
I traded My leaker off. I repaired the front seal but wasn't about to pull the engine and tranny to repair the rear with 251,053 miles
on the little GXE.. hahahaha It changed it's own oil, I just changed the filter...
WARNING:Wastegates,Blowoff Valves,and Boost Controllers can cause unforseen urges to crap your pants.
93 Nissan Hardbody**SOLD**
03 White SpecV(GONE)
Now 06 Mustang GT
Dwntyme is offline   Reply With Quote
Old Sep 30th, 2003, 01:12 PM   #5 (permalink)
shughes
I replaced the front seal this weekend. It appears the oil leak is much better then it used to be but still some oil is leaking. I will check up on the oil pressure switch as mentioned in the earlier post. The leak is still on the passenger side. I guess I could have always not installed the front seal correctly but it looked good when I put it in.
Old Sep 30th, 2003, 08:32 PM   #6 (permalink)
shughes
JWolfe-
Thanks for the tip. I think I found it to the right of the oil filter and it was indeed wet with oil under the rubber boot.
Old Feb 8th, 2004, 01:50 PM   #7 (permalink)
tedrik13
Check your timing chain "cover"
I ran a dye test through the engine and discovered it was the timing chain cover(the bolts come loose). It is very expensive to fix(a lot of labor to get at it!). My dealer and PEP BOYS wanted $900.00 to 1100.00(dealer of course) to fix it. I add about 1/2 qt. oil approximately every 1,800 miles(slow leak which hasn't worsened in 10 months. It's cheaper than the permanent fix until I find a backyard mechanic that I can trust. I just live with the oil stains in the driveway. Also check(as I will) to see if you can reach the bottom bolts to the cover from underneath. My neighbor says that sometimes by just tightening the bottom bolts-it solves the problem. Take care.
tedrik13 is offline   Reply With Quote
