Old Sep 20th, 2003, 01:14 PM   #1 (permalink)
gERVs
gERVs's Avatar
ga16i, with ga16de head?
would it be possible to just swap the head(along with ecu harness and all that) and keep the same ga16 block and tranny in place?
gERVs is offline   Reply With Quote
Old Sep 20th, 2003, 03:20 PM   #2 (permalink)
Galimba1
Proud owner of a GA16i
Galimba1's Avatar
Send a message via AIM to Galimba1
I don't think so, I've heard that the bolt positions on the ga16i head are slightly different than the ga16de. Can anyone confirm this? They might actually fit.
B12
Galimba1 is offline   Reply With Quote
Old Mar 23rd, 2004, 02:38 AM   #3 (permalink)
Galimba1
Galimba1's Avatar
OK, I thought I'd drag this up because I've gone to my local pick n' pull and looked at a few engines. At the end of the day, I pulled a GA16DE head for like $27 +tax. Taking the head gasket, and comparing the GA16DE head to the GA16i crankcase, the only difference is the timing chain cover. I mean the bolt pattern lines up exactly except for the timing cover bolt pattern, where the gasket pattern comes short compared to the head. The next step is to acquire a timing chain cover off a GA16DE and see if the bolt pattern aligns with that on the GA16i. Just an interesting thought I thought I'd like to share.
Old Mar 23rd, 2004, 06:14 AM   #4 (permalink)
Slayer2003
Peek-a-boo....
Slayer2003's Avatar
Send a message via AIM to Slayer2003 Send a message via Yahoo to Slayer2003
.......i have my original black vc from my b14 if yah want it changed out the factory plastic one for a b13 aluminum one.
Originally Posted by RoadWarrior - ocforums.com
Yes, SATA is faster however..... putting full spec formula one tires on a 1.6L stock honda civic will not make it capable of 200Mph......
SEARCH BUTTON. USE IT OFTEN!
Slayer2003 is offline   Reply With Quote
Old Mar 23rd, 2004, 01:03 PM   #5 (permalink)
Galimba1
Galimba1's Avatar
Thanks anyways, but an AL valve cover came with the head that I grabbed from the JY. What I'm looking for is a timing chain cover from a GA16DE, to see if it will fit on a GA16i botom end.
Old Mar 23rd, 2004, 10:57 PM   #6 (permalink)
Mervic
Soon to be GA16it
Mervic's Avatar
I think you might have issues of piston to valve clearance since the 16i has only 12 valves, while the 16DE has 16 which has the relief cut for the valves. I've asked about the compatability of both engines head and most the response was not to bother since you will need the harness and ECU installed, might as well just swap the whole engine, much easier.
Mervic is offline   Reply With Quote
Old Mar 26th, 2004, 11:06 PM   #7 (permalink)
Galimba1
Galimba1's Avatar
Crap, forgot about the relief cut on the pistons. That means I'd have to swap those out too. Well, so much for this experiment.
Old Mar 26th, 2004, 11:19 PM   #8 (permalink)
recycled_toddler
Moved on...Ciao!
recycled_toddler's Avatar
Angry
Shit! I thought I had it good...that'd run me $50 up here! How much for an engine? $150 here...but it's got manifolds, throttle body, pulleys...everything but flywheel and alternator.
Later, taters; Off to a better place. Catch me there!
recycled_toddler is offline   Reply With Quote
Old Mar 27th, 2004, 08:22 AM   #9 (permalink)
wes
Wise Cracker
wes's Avatar
Send a message via AIM to wes
With all the differences it is probably easier to do a complete swap given the engine price.
www.NissanPerformanceMag.com
JWT
www.notnser.com
Old Apr 5th, 2004, 12:43 PM   #10 (permalink)
1989SentraOK
Tha Sleepin' B12
1989SentraOK's Avatar
Send a message via AIM to 1989SentraOK Send a message via MSN to 1989SentraOK Send a message via Yahoo to 1989SentraOK
Old thread, but I do have to add something. Isn't the GA16DE DOHC? The GA16i is SOHC.
My CarDomain Page
You can build a fast Honda. You can build a faster Nissan.
1989SentraOK is offline   Reply With Quote
Old Apr 5th, 2004, 03:03 PM   #11 (permalink)
NismoSS
i dont know if Ga16De head is functionally with GA16 OHC, , but ,, remember then you never can use the ECU, you have a change the carburated system for ECCS manifold and all sensors .. is complicated this process,
other option is used carburated GA16DE 16V , , hehehhe i have this project but a GA16DNE, or MEXICAN POWER ,, jajajja
is more easy to buy an engine GA16DE with ECCS y VTC ,ECU and wires. . and to do a Swap ..
NismoSS is offline   Reply With Quote
