» Sponsors
» Sponsors
Go Back   Nissan Forums: Nissan Forum > Nissan Models > Sentra, Pulsar, NX, B14 200SX > GA16DE 1.6L Engine
Old May 5th, 2002, 04:53 PM   #1 (permalink)
ex-Super *********
PatScottAKA99XE's Avatar
Send a message via AIM to PatScottAKA99XE Send a message via Yahoo to PatScottAKA99XE
Exclamation Oil temp and Oil pressure gauges are done!
Hello,
Well I went down to the shop I work at today and hooked up the remote oil filter kit and my oil gauges. The install went pretty good. Took me about three hours(not at all in a hurry). All readings are what I expected: oil psi, idle cold-50psi, hot(180deg)-13psi 3krpms-about 60psi. Also the remote system uses about 3/4 of a quart more oil. I wired the gauge lighting to light up with my cluster lights, also I put a switch before them so I can shut off the lights to the tach and the new gauges if I want.
I guess the next thing to do is find a spot to put my water temp sender so that I can hook that gauge up as well. Questions/comments, drop me a line. Link to my website for pics and my email are below(one pic of filter location on project page).
Patrick Scott
Yeah, thats a roll cage in there.
I shall call him...Mini-Me
PatScottAKA99XE is offline   Reply With Quote
Old May 5th, 2002, 06:01 PM   #2 (permalink)
Platinum
CarbonBlack200's Avatar
Send a message via AIM to CarbonBlack200
Cool nice work
Looks good! I really need to get oil pressure/temp gauges. I saw your page and noticed you installed your meters on the AC vent. Did you just kill that thing or relocated somewhere else?
I also liked your relocated oil filter. I hate changing oil filter on my car. Everytime I do it, I have to rise my car up and dive under the car to do it. I always get oil "BAM!!" all over on me. I hate that.
CarbonBlack200 is offline   Reply With Quote
Old May 5th, 2002, 09:14 PM   #3 (permalink)
ex-Super *********
CarbonBlack200,
Yep I killed the vent, my car does not have A/C(base model) and I never run the heat through those vents, so its not a problem. As for oil changes, I think it might make a mess under it when I change the filter, oh well the sacrifices we make.
Patrick Scott
need to know about aftermarket gauges LilJoe_ SR-Series Engines (DE/VE) 4 May 19th, 2003 06:12 PM
GA!^DE oil pressure gauge install go4broke44 B14 95-99 chassis 4 Apr 26th, 2003 05:16 PM
Do you want oil psi and temp gauges now, but may add a oil cooler later. Look! PatScottAKA99XE GA16DE 1.6L Engine 5 Jul 10th, 2002 11:42 PM
For those that want an easy way to install oil psi and oil temp guages. Look here! PatScottAKA99XE GA16DE 1.6L Engine 15 Jul 10th, 2002 04:26 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
