the easiest method for hooking up an aftermarket oil pressure gauge is to tap into the stock oil pressure sender location (on the back of the block near the filter), you need to use a T fitting with the proper threads. the stock sensor uses a 1/8 BSPT and most aftermarket gauges are 1/8 NPT, there is a company that makes fittings specifically for the sentra sr and ga engines, I forget the web address... I'll post it when I get home (its George Roffe's company)
-dave
92 Sentra 1.6T
