Head gasket replace... - Nissan Forum
post #1 of 12 Old Apr 9th, 2017, 08:47 PM Thread Starter
Hey all! So, I gotta replace the head gasket of my sentra... but i have a few questions before i start.
should i replace the cylinder head bolts? the fsm doesnt say anything about replacing them.
should i replace the valve seals while everythings off? also do i have to resurface the head and/or block even if it isnt warped? would the engine block even warp??
oem vs federal mogul (aka felpro) gasket?
any other things i should do while the head is off?
thanks.
Sent from my iPhone using Tapatalk
carguy101 is offline
post #2 of 12 Old Apr 10th, 2017, 05:05 PM
If the service manual doesn't say to replace them then it's probably not needed.
If you remove the cylinder head I'd take it to a machine shop and have it checked. The engine block can warp but it's not as likely. You should still check it with a straight edge to be sure, though.
Unless there is some inherent problem with the OEM gasket that's what I'd use. Consider that it got you this far before it failed. What caused it to need a head gasket? Did it overheat?
1998 Nissan 200SX SE 5spd - Blue
John Clark is offline
post #3 of 12 Old Apr 10th, 2017, 11:16 PM Thread Starter
the weird thing is i dont know why the head gasket failed! i just didnt start the car for a few days then poof! broken head gasket!
post #4 of 12 Old Apr 15th, 2017, 11:11 PM
That almost never happens. Head gaskets don't just fail for no reason, usually unless it's real high mileage. Usually there is an overheating event that precedes the head gasket failure.
I just replaced the thermostat and put in all new coolant hoses (all 10 of them) on mine, to hopefully prevent just such a problem.
Next project is a new AC compressor, condenser, rubber hoses, filter-dryer, and expansion valve.
post #5 of 12 Old Apr 16th, 2017, 08:23 PM Thread Starter
well the car has past 300k kilometers and its been sitting for 9 years since then...
ive already replaced all my coolant hoses due to them cracking.
post #6 of 12 Old Apr 19th, 2017, 10:47 PM Thread Starter
UPDATE: just one more question, i got the head out and 4 of the lifters fell off (when i turned the head upside down). i forgot to mark them so i dont know the original positions... is it okay if they get interchanged?
post #7 of 12 Old Apr 21st, 2017, 03:14 PM
Those are measured spacers for valve adjustment. They may be the same but they may not. You'll need to measure their thickness to determine. If you get the head reconditioned they may be able to help you.
post #8 of 12 Old Apr 22nd, 2017, 10:44 PM Thread Starter
alright thanks, im replacing all the valves so i think i have to check the clearances and change the shims anyway...
post #9 of 12 Old Apr 23rd, 2017, 04:06 AM Thread Starter
question again: is the engine block surface clean enough?
ive been using scotch brite pads and wd-40 to clean the gasket surface...
post #10 of 12 Old Apr 23rd, 2017, 10:01 AM
Sup Mod keeping the peace
rogoman's Avatar
Most vehicle manufacturers use Torque-To-Yield (T-T-Y) head bolts, especially on engines with aluminum heads. They provide more consistent clamping loads across the entire head-to-block mating surface. Since T-T-Y bolts are designed to stretch, reusing them can cause improper or uneven torque and clamping force. Stretched bolts can damage threads in the engine, especially on aluminum blocks, and since the bolts are weakened, they may break if re-torqued. You should always replace the bolts.
KA-T for life, yo!
rogoman is online now
post #11 of 12 Old Apr 23rd, 2017, 03:28 PM Thread Starter
thanks, ill replace the head bolts. they're a bit rusty anyways...
post #12 of 12 Old Apr 23rd, 2017, 03:52 PM
rogoman's Avatar
I might also add:
T-T-Y bolts are tightened in a series of stages and in sequence. T-T-Y bolts are generally tightened in sequence to what is known as a snug torque value. This snug value is to ensure that the component, in this case say a cylinder head is firmly located on the block. Torque is further applied in sequence through a series of motions only this time instead of torque load being measured, angle of rotation is measured by using an angle wrench.
Follow the tightening specs as outlined in the FSM. Always clean the threads where the bolts pass through, any thread damage, corrosion or rust will create excessive friction giving you a false torque reading, robbing you of valuable clamping force. Using engine oil, lightly oil the threads and under the heads/washers on the T-T-Y bolts as specified by the FSM. Clean, oiled threads prevent binding, allowing for accurate and consistent torquing. Be careful not to over-oil the bolts, especially if they are threading into a blind hole. Too much oil will hydro-lock the bolt and give false torque readings.
KA-T for life, yo!
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
Head Gasket & Timing Set replace newave Stanza 0 Feb 18th, 2016 11:28 AM
2002 Sentra w 278,000 miles - replace head gasket or engine? Swede67 B15 2000-2006 1 Nov 29th, 2014 01:12 PM
HEAD GASKET BLOWN 92 V6// K&N OR REPLACE GASKET mentawai69 HB Truck 0 Nov 16th, 2011 12:03 PM
Head gasket to shit, need to replace. should i get a new engine? Sally_sentra GA16DE 1.6L Engine 1 Jun 14th, 2006 10:55 AM
How hard is it to replace a pickups head gasket? rx7 punk Naturally Aspirated 3 Jul 20th, 2005 04:37 PM
You may post new threads
You may post replies
BB code is On
