Old Jun 6th, 2003, 11:37 AM   #1 (permalink)
yafayu
yafayu's Avatar
HELP! High idle speed
I have a 1987 Nissan Pulsar, everytime i start the engine, the rpm goes around 1100 - 1300, but i checked my manual, it says normal idle speed should be 800 rpm, does anyone know what caused my problem?? thx for help
~!!*YaNg*!!~
1987 Nissan Pulsar NX E16i 5 speed
MY 1987 Pulsar Pictures
yafayu is offline   Reply With Quote
Old Jun 6th, 2003, 12:59 PM   #2 (permalink)
LIUSPEED
Vendor
DNE's VZR Conversion
LIUSPEED's Avatar
Send a message via AIM to LIUSPEED Send a message via MSN to LIUSPEED Send a message via Yahoo to LIUSPEED Send a message via Skype™ to LIUSPEED
it should be normal.
my sentra does that.. it goes to hi rpm @ first start then it slowly adjust it self down the the lower rpm.
hope this helps.
LIUSPEED is offline   Reply With Quote
Old Jun 6th, 2003, 04:53 PM   #3 (permalink)
psuLemon
i pwn your mom
psuLemon's Avatar
Send a message via AIM to psuLemon
my 98 200sx idles at 1300 when i first start it and then adjust down to 900 or 1000 after it starts running... it sounds normal though
Originally Posted by hendrix
I can't wait until Hurrican Jamal sweeps up the east coast and steals the wheels and stero out of your car
psuLemon is offline   Reply With Quote
Old Jun 6th, 2003, 10:36 PM   #4 (permalink)
Mack
Mack's Avatar
I agree with these posts - a lot of cars have a higher idle at start-up, but this shouldn't continue very long, except for say, in cold weather.
My Sentra used to idle very unpredictably (turned out to be a fuel filter/O2 sensor/dirty throttle body issue) and before I checked these items, I simply brought the idle up a little to keep it from dying as much (bad idea). Anyway, just in case you didn't know, there is a little screw that keeps the throttle cord taught at a certain position for idling. If your car maintains an unhealthily-high idle, I'd suggest dropping the idle speed a little. It's not extremely hard on your engine to idle faster - but it's not great either.
Hope you can resolve your problem.
1993 Sentra XE
5 Speed 2 Door
Mack is offline   Reply With Quote
