Old Jun 4th, 2003, 02:33 AM   #1 (permalink)
LoOoD
trouble starting engine, engine dies when you give it gas
like the title says.. every now and then.. maybe twice a week. The engine doesn't want to start, but finally does after 20 - 30 seconds turning the key. I have to make sure I don't step on the gas when this happens.
Then when I give the engine gas after this the engine dies out..
But after 1 minute of the engine running everything is back to normal and can stop and start the car w/ ease. And I can gas it all I want and it still runs...
Ideas what this may be?.. =) I'll take it to the mechanic tomarrow, but just was curious... oh btw this is a GA16i in a 89 sentra..
LoOoD is offline   Reply With Quote
Old Jun 4th, 2003, 07:06 AM   #2 (permalink)
himilefrontier
265k miles and counting..
himilefrontier's Avatar
Send a message via AIM to himilefrontier
Just a guess,but it sounds to me like a fuel pressure problem.Is there a leak somewhere in the fuel lines?It could also be an electrical short in the engine harness.Or maybe a bad ignition module since they trigger the injection in many cars and can have an intermittent problem.
1998 Nissan Frontier XE/2wd/5spd 1 owner, 264k miles
1985 Olds Cutlass, 350 Chevy, owned for 14 years
WANTED: 1968-1973 Datsun 510 or 1991-1994 Sentra SE-R
http://www.myspace.com/junkyardengineer
himilefrontier is offline   Reply With Quote
Old Jun 4th, 2003, 08:01 PM   #3 (permalink)
psuLemon
i pwn your mom
psuLemon's Avatar
Send a message via AIM to psuLemon
i would agree with himilefrontier.. it actually sounds like your car is dumping too much fuel and making it run really rich.. my friend had the same problem with his ford probe...you might want to replace your fuel filter if you haven't done that in awhile and then check your fuel pump and fuel pressure regulator..
Originally Posted by hendrix
I can't wait until Hurrican Jamal sweeps up the east coast and steals the wheels and stero out of your car
psuLemon is offline   Reply With Quote
Old Jun 5th, 2003, 04:43 PM   #4 (permalink)
GA15
Send a message via ICQ to GA15
Check your Fuel pump. My buddy has s skyline GTS. Whenever he steps on the accelerator for about 10 seconds, the engine totally shuts down. He changed the fuel pump and it worked fine now.
1994 Nissan Sunny B13 SE-R J-Spec. Actually a rebadged EX-Saloon with 4-wheel disc brakes and 9000rpm tach from the USA SE-R and a standard GA15DS engine that can accelerate till 190km.
GA15 is offline   Reply With Quote
Old Jun 6th, 2003, 11:30 PM   #5 (permalink)
SergioCR
Nissan Fanatic
SergioCR's Avatar
Send a message via MSN to SergioCR
Re: trouble starting engine, engine dies when you give it gas
It sounds to me like a low pressure at the gas pump... have you checked the injector located at the top of the throttle body when manually rev. up the engine? it should spread gas inside if it doesn't i would go with low fuel pressure... or the MAF sensor damaged... have the fuel pressure checked.... it should be around 35psi at idle...
SergioCR is offline   Reply With Quote
Old Jun 7th, 2003, 01:05 AM   #6 (permalink)
verno-dub
verno-dub's Avatar
Change the fuel filter yet?
verno-dub is offline   Reply With Quote
Old Jun 19th, 2003, 05:44 PM   #7 (permalink)
LoOoD
spark plugs.. runs fine.
