Old May 25th, 2003, 09:23 AM   #1 (permalink)
bwolf123
Send a message via AIM to bwolf123
Power loss/slow acceleration
I am a newbie. Dont know a heck of a lot about engines. I have a 96 sentra which is slower than it used to be accelerating. I cleaned the air filter, replaced spark plugs, new spark plug wires, new distributer. However, when I replaced the fuel filter, it was full of dark disgusting gas. Previous owner must not have changed it often (or ever). Do you think my injectors could be clogged? If so, what should I do?
What else do you think I should check into?
Bwolf123@aol.com
1996 Sentra, nothing special yet. Have to buy diapers instead.
bwolf123 is offline   Reply With Quote
Old May 25th, 2003, 10:16 PM   #2 (permalink)
Token Moron
My ass, your face
Token Moron's Avatar
Send a message via AIM to Token Moron Send a message via MSN to Token Moron
injectors might be clogged/dirty...usually i use STP fuel treatment and that works for me...also check your throttle cable, it might be loose
91 se-r : sr20det= the beast
96 sentra : ga16de= pimpness
00 frontier : ka24de= tow truck
01 sentra : gq18de= stock mofo
Token Moron is offline   Reply With Quote
Old May 26th, 2003, 05:52 AM   #3 (permalink)
bwolf123
I will try that, thanks for the help.
Bwolf123@aol.com
Old May 26th, 2003, 09:42 AM   #4 (permalink)
sentra2nr
Shift_for_Brains
sentra2nr's Avatar
Talking fuel injectors clogged
Sea Foam!!!
at first I didnt believe that this stuff was that good, but DAMN!!! That stuff is the shiznit. It smoothed out my idle bigtime!!! I poured some in my tranny as well, and it shifts better too. good to get rid of varnish on internals of engine.
I like work, it fills up the days between weekends...
sentra2nr is offline   Reply With Quote
Old May 26th, 2003, 10:28 AM   #5 (permalink)
bwolf123
thanks a lot. I'll try it out if I can find it.
Bwolf123@aol.com
Old May 26th, 2003, 08:08 PM   #6 (permalink)
Token Moron
My ass, your face
Re: fuel injectors clogged
Originally posted by sentra2nr
Sea Foam!!!
seafoam ehh? never heard of it, where can i find this stuff?
Old May 26th, 2003, 09:01 PM   #7 (permalink)
Katana200sx
P.O.S. Truckdriver
Katana200sx's Avatar
Send a message via ICQ to Katana200sx Send a message via AIM to Katana200sx
yea ive never heard of it either..have any info?
Katana200sx is offline   Reply With Quote
Old May 26th, 2003, 09:39 PM   #8 (permalink)
bwolf123
I checked into it a little too. www.seafoamsales.com
Bwolf123@aol.com
Old May 27th, 2003, 07:08 AM   #9 (permalink)
sentra2nr
Shift_for_Brains
sentra2nr's Avatar
sea foam
comes in a red&white can. I have had good luck with finding it at carquest and Advance Auto. They also make a product specifically for transmissions called Trans Tune.
Old May 31st, 2003, 10:32 AM   #10 (permalink)
fritzfry
if the power loss is very pronounced, and the above suggestions don't help, and your car ultimately dies...your fuel pump could be going.
GA16DE
beauty is in the eye of the beer holder :cheers:
fritzfry is offline   Reply With Quote
